PWM gen
7 years 10 months ago - 7 years 10 months ago #121880 by Sytreca
Replied by Sytreca on topic PWM gen
There is a possibility to connect serial with RS323,RS485 or RS422.
The 7i66 is connected to 7i44 and this is connected to 5i23.
But all the ports on 7i44 are most likely gonna be used up.
On the 5i23 P3 is still available.
Last edit: 7 years 10 months ago by Sytreca.
7 years 10 months ago #121882 by andypugh
Replied by andypugh on topic PWM gen
You can probably arrange to have a high-frequency (up to MHz) PWM generated on one of the 5i23 pins.
Alternatively the 7i83 would do what you want, but seems overkill for an individual analogue output: store.mesanet.com/index.php?route=produc...83_88&product_id=122
It's a pity there isn't a single-channel smart-serial version of the Spinx1
store.mesanet.com/index.php?route=produc...t_id=205&search=spin
7 years 10 months ago #121884 by Sytreca
It's a commander CD75-750. i don't know with which component this corresponds.
7 years 10 months ago #121886 by Sytreca
If i generate a PWM on the 5i23, is it still possible to create a 0-10V signal?
I tought the 5i23 only can get 5V on it's pins.
7 years 10 months ago #121887 by PCW
Replied by PCW on topic PWM gen
You can get 10V but it needs an op-amp (to change the 0..5V analog to 0..10V)
or some kind of level translator for the PWM before filtering. (our SPINX1 does this)
Heres an example schematic for a 7I66 output filter:
Time to create page: 0.178 seconds
