Hi Andy. When you make files per tool, do you select a collection of ops and click post? With that file, can LinuxCNC safely start in the middle? I just want to be sure I'm not overlooking a feature. I'm considering posting all the ops into a single file, then breaking that up by tool change (or by operation or by a CAM comment), copying the original preamble and postamble to each file. Does this approach sound reasonable? Thank you
