siemens servo compatibility
7 years 9 months ago #124019 by Yannis
Replied by Yannis on topic siemens servo compatibility
Is this more helpful
7 years 9 months ago #124235 by andypugh
You should be able to use them with LinuxCNC, if you can figure out how to configure them for analogue voltage control rather than Profibus.
You would also need to find out which pins/connectors need be connected for analogue voltage control.
The following user(s) said Thank You: Yannis
7 years 9 months ago #124290 by Yannis
I don't have the knowledge to do that
thanks for the info
7 years 9 months ago #124298 by Todd Zuercher
That is what Google is for, use it to dig up a manual for your drives and read it.
7 years 9 months ago #124376 by uli12us
Replied by uli12us on topic siemens servo compatibility
siemens have a great user documentation area. You can find nearly all documentation for all motors, drivers software. The Problem is, all parts from the newer machines are digital controlled.
support.industry.siemens.com/cs/document...dti=0&dl=en&lc=es-CO
Time to create page: 0.209 seconds
