Question : 5axis simultaneous setup in LCNC
- KevKim
16 Jan 2019 09:45 - 17 Jan 2019 00:16 #124285
by KevKim
Question : 5axis simultaneous setup in LCNC was created by KevKim
Hello world,
A new subscriber here to ask some questions.
I am playing with LCNC inside a virtual box, 2.8 dev version and to grab some idea on multi-axis configuration.
I can successfully install and launch the program to see how kinematics works and here I am facing a challenge.
(ps. okay, I got how to insert link... the above is when I input g0A45, and g0A-45 only.. nothing else)
I just captured and uploaded this just to ask a question.
Why Y/Z axis move (seems like linked) together when I put G0A45 or G0A-45 here??
Weird thing is that while rotating A, I am clearly seeing Y/Z move together but DRO shows no change.
It does seem like kinematics/graphics engine desperately tries to point its original spot on the surface while keeping same distance but I don't get this when cam software does all that kind of complex coordinate transformation internally and makes me gcodes.
Is it just a matter of graphical showing issue?
I am trying to modify and cleanup a postprocessor and I want my linuxcnc running inside my workstation for immediate test and proving.
Can someone tell me if it's from vismach gui script or kinematic engine itself?
Regards,
KevKim
Regards,
KevKim
Last edit: 17 Jan 2019 00:16 by KevKim.
- Thank you received: 1471
16 Jan 2019 17:34 #124297
Replied by Todd Zuercher on topic Question : 5axis simultaneous setup in LCNC
If you are doing all the kinematics work in CAM then you don't want to do it again in Linuxcnc. Just set up a config with trivkins for this.
Use a 5 axis kinematics configuration if your CAM is outputting simple Cartesian code and you want Linuxcnc to do the tool tip calculations. (What it looks like you have in your simulation.)
The following user(s) said Thank You: KevKim
- Hakan
- Thank you received: 453
16 Jan 2019 21:18 - 16 Jan 2019 21:20 #124305
by Hakan
Replied by Hakan on topic Question : 5axis simultaneous setup in LCNC
I always change the youtube link to https: //www.youtube.com /watch?v=id instead of the youtu.be/id syntax. Maybe someone can add this feature?
Exactly, it is the kinematics that does it. You surely have a kinematic where x,y,z,a,c means the tool's position and orientation. It is up to linuxcnc to position the axis' so this happens. You get the effect that several axis can/will move when you think you ask it to make a simple translation.
Last edit: 16 Jan 2019 21:20 by Hakan.
- KevKim
17 Jan 2019 01:45 #124312
by KevKim
Replied by KevKim on topic Question : 5axis simultaneous setup in LCNC
many tnx for the quick answer!
So then what I will be needing is trivkins instead of xyzackins.
I picked up a sim-9axis, which already has trivkins, and inserted vismach gui within .ini file
and here comes a new challenge.
# vismach xyzac-trt-gui items
HALCMD = loadusr -W ./xyzac-trt-gui
HALCMD = net :table-x joint.0.pos-fb xyzac-trt-gui.table-x
HALCMD = net :saddle-y joint.1.pos-fb xyzac-trt-gui.saddle-y
HALCMD = net :spindle-z joint.2.pos-fb xyzac-trt-gui.spindle-z
HALCMD = net :tilt-a joint.3.pos-fb xyzac-trt-gui.tilt-a
HALCMD = net :rotate-c joint.5.pos-fb xyzac-trt-gui.rotate-c
HALCMD = net :tool-offset motion.tooloffset.z
# HALCMD = net :tool-offset trivkins.tool-offset xyzac-trt-gui.tool-offset
# HALCMD = net :y-offset trivkins.y-offset xyzac-trt-gui.y-offset
# HALCMD = net :z-offset trivkins.z-offset xyzac-trt-gui.z-offset
# HALCMD = sets :y-offset 20
# HALCMD = sets :z-offset 10
Remark-treated lines are making error due to absence of pins(that's what error message saying).
Without these lines, gui model works as I wanted it to behave.
Should I add pins to .hal file? Is that all I need to work it or any further process needed?
If so, what material to read to learn these stuffs?
I am no software expert, no linuxcnc expert.
I just want it to be setup for my work.
environment : current wheezy version(stock iso) + LCNC 2.8 recent dev version(stock built one) inside vmware
regards,
Kevin
regards,
Kevin
- KevKim
17 Jan 2019 02:07 - 17 Jan 2019 09:05 #124315
by KevKim
One thing that just hit my head is that....
Do I really need those offsets for trivkins?
It looks like they are needed because they have to move in harmony, but with trivkins, I don't think I have to consider that.
Am I in right direction?
Last edit: 17 Jan 2019 09:05 by KevKim.
- Hakan
17 Jan 2019 09:08 #124338
by Hakan
As far as I understand you don't need the offsets in linuxcnc.
With trivkins you need that info in the CAM post processor. The machine description is now
moved to the CAM system.
With the little experimentation I have done on this subject, I think you are best off with a tcp kinematics
(that is, NOT trivkins) for a 5 axis machine. The movements are interpolated in world coordinates, not in
axis (or rather joint) coordinates.
The challenge comes when jogging. Fortunately it is possible to hit "$" or F12 in many guis to enter joint jogging mode..
Jogging then takes place in joint coordinates and one doesn't need to twist the brain.
- Thank you received: 4648
17 Jan 2019 14:00 #124353
Replied by andypugh on topic Question : 5axis simultaneous setup in LCNC
Just to further explain:
In the G-code there are two things that the XYZABC words can mean.
1) They can refer to the actual positions of the machine axes, with a 1:1 mapping (trivkins)
2) They can refer to the location and angle in space of the tool itself. (TCP) This is a more flexible approach (it means that the CAM package does not need to have an exact copy of the machine geometry, and that the G-code can run on more than just the one machine it was made for)
- KevKim
17 Jan 2019 15:36 #124355
by KevKim
Tnx all,
I am pretty much noob at this subject, just used whatever provided so far.
To me, I think giving CAM same geometry and see it working is more straightforward to understand.
Hence I today worked a lot to resolve this issue.
I guess its more than 50% working as intended.
- modified vismach gui for the size/work envelope
- trivkins
was never an easy job for me to complete with little accumulated understanding....
Anything weird?
KevKim
- trivkins
Anything weird?
KevKim
- pl7i92
- Thank you received: 358
17 Jan 2019 16:06 #124359
by pl7i92
Replied by pl7i92 on topic Question : 5axis simultaneous setup in LCNC
IN Most cases the Machine builder will try to get the Rotation Point in the AXIS mid point
so all is zero lined up and the Standard postprocessors of all multiaxis CAM will get yoiu a perfect Gcode
so it is as a Machine joints Cam not just build a machine and hope the cam will fit your need
- KevKim
18 Jan 2019 09:06 #124390
by KevKim
Quite some hard learning while customizing this software for my needs.
As mentioned, whole environment is from most recent distribution of linuxcnc iso file,
then deleted 2.7 and added 2.8, inside VMware.
This is the part of my .ini file, which is a sample sim and I modified just a little bit
[DISPLAY]
OPEN_FILE = ./examples/impeller-7bl-xyzac.ngc
JOG_AXES = XYZC
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2
PROGRAM_PREFIX = ../../nc_files
INTRO_TIME = 1
EDITOR = gedit
TOOL_EDITOR = tooledit z diam
GEOMETRY = -A-B-CXYZUVW
TKPKG = Ngcgui 1.0
NGCGUI_FONT = Helvetica -12 normal
NGCGUI_SUBFILE = test-xyzac.ngc
I tried some other GEOMETRY order but nothing is satisfactory.
Vismach is working correctly, I think it happens only in the toolpath window within linuxcnc.
Tried normal axisgui too but result is same - which I think is natural, they use same graphics module....
Here is my progress, LCNC screen is starting at about 2:10.
Can someone bring me some light on this toolpath-drawing issue?
regards,
Kevin
[DISPLAY]
JOG_AXES = XYZC
DISPLAY = gmoccapy
INTRO_TIME = 1
EDITOR = gedit
TKPKG = Ngcgui 1.0
regards,
Kevin
Time to create page: 1.307 seconds
