Default steplen puzzle.
7 years 9 months ago #125066 by JohnPrime
Hi all,
My mill is running quite happily on software parallel port stepping and, just for laughs, I am in the process of reproducing its config on another computer running master into a MESA 7i92; however, I see this in the existing parallel port hal-file:
setp stepgen.0.position-scale [AXIS_0]SCALE setp stepgen.0.steplen 1 setp stepgen.0.stepspace 1
According to man stepgen this should give me a steplen of 1ns, which is implausible. I'm guessing that 'steplen 1' is invoking a default, but can't find out what in the docs. Where should I be looking for clues?
Many thanks,
John.
7 years 9 months ago - 7 years 9 months ago #125074 by PCW
Replied by PCW on topic Default steplen puzzle.
"steplen 1" is used with the software stepgenerators "reset" mode where the
steplength is set by the global reset time (and not the per channel steplen parameter).
Last edit: 7 years 9 months ago by PCW.
The following user(s) said Thank You: JohnPrime
7 years 9 months ago #125281 by JohnPrime
Replied by JohnPrime on topic Default steplen puzzle.
Thanks Peter, massively helpful.
I found a reference in the main LCNC pdf:
"7.3.1.4 Use steplen, stepspace, dirsetup, and/or dirhold"
All clear now :)
John.
Time to create page: 0.296 seconds
