native cam vs glade probing
7 years 7 months ago #127936 by tony978
so I'm running in to an issue that is confusing . Under native cam probing works. But using askjerry's glade sae probing , I get a tripped error . I'm using debounce and parallel port to breakout board . I just don't get why one would work and not the other ?
thank you
7 years 7 months ago #127967 by andypugh
Are they both using the same G-code? (G38.2, for example)
7 years 7 months ago #127991 by pl7i92
Replied by pl7i92 on topic native cam vs glade probing
glasde uses the 1ms servo tread while native cam the real G38 so there is a different that trips the error
7 years 7 months ago #128004 by tony978
Replied by tony978 on topic native cam vs glade probing
Thank you ! Now to figure out how to get it to work .
Time to create page: 0.337 seconds
