Terminal blocks for grounds for inputs.
- Leon82
- Thank you received: 79
10 Mar 2019 15:59 #128246
by Leon82
Terminal blocks for grounds for inputs. was created by Leon82
Maybe I'm searching the wrong terminology but are there blocks for linking all the ground for inputs , so you can run a single wire to the breakout board?
- pl7i92
- Thank you received: 358
10 Mar 2019 17:24 #128253
by pl7i92
Replied by pl7i92 on topic Terminal blocks for grounds for inputs.
The following user(s) said Thank You: Leon82
- OT-CNC
- Thank you received: 75
10 Mar 2019 17:30 #128256
by OT-CNC
Replied by OT-CNC on topic Terminal blocks for grounds for inputs.
I like using din rail terminal blocks for the wiring or you can do crimp screw terminals etc.
- Thank you received: 4144
10 Mar 2019 19:18 #128266
Replied by rodw on topic Terminal blocks for grounds for inputs.
I used one of these for both th +24V rail and the -24v rail but will be the wrong country for you no doubt.
www.jaycar.com.au/16-way-100a-brass-distribution-bar/p/SZ2004
Search for bus bar.
Search for bus bar.
- Leon82
10 Mar 2019 19:43 #128268
by Leon82
Replied by Leon82 on topic Terminal blocks for grounds for inputs.
Thanks, I know what I'm looking for now and see some that are available here
In
In
- Leon82
10 Mar 2019 21:39 #128273
by Leon82
What guage wires are your xh connectors for the step dir signals?
like the one i use here
you can also see them in this video
- pl7i92
11 Mar 2019 07:15 #128296
by pl7i92
the wirers are
JST-XH-3S
LIPO Silicon double isolated
www.ebay.de/itm/10-Stuck-Set-JST-XH-30cm...gskabel/182501405867
JST-XH-3S
- Thank you received: 4652
11 Mar 2019 13:26 #128327
Replied by andypugh on topic Terminal blocks for grounds for inputs.
There are commoning strips for DIN rail terminals.
photos.app.goo.gl/zTbkjRHgE4PekPSZ8
The top 6 are bussed together for 0V, then two for 12V and the next 6 for 24V.
The strips fit in the middle slot and then screw to the internal metal conductors.
Unfortunately the commoning strips are specific to each brand of terminal block, and are hard to find in the catalogues as nobody seems to have decided what to call them.
www.cef.co.uk/catalogue/categories/din-r...terminal-jumper-bars
My terminals in the picture above use the many-screws type.
There are also specific commoning blocks:
uk.rs-online.com/web/c/connectors/termin...ls/commoning-blocks/
11 Mar 2019 13:35 #128333
Actually, "din jumper" works on the RS web site too:
uk.rs-online.com/web/c/?sra=oss&r=t&searchTerm=din+jumper
- Leon82
11 Mar 2019 13:37 #128335
by Leon82
O ordered one of these, it's got the terminals jumpers ends and rail section.
www.amazon.com/Erayco-Terminal-Press-Fit...8&pd_rd_i=B07KRDJCYB
