Reverse run on BeagleBone Black
7 years 7 months ago #128879 by Tower
Bosston88 wrote: I found where hal_init sits in LCNC: src/hal/hal_lib.c and hal_xinit in MK: src/hal/lib/hal_comp.c. I'll give it a try to add this function in hal_lib.c, but will it work...?
It's not going to be easy. The HAL engines in both Machinekit and LinuxCNC diverged quite a bit over the years after the fork and now the Machinekit one is quite reworked (with the multicore and instantiable components support, new HAL objects and whatnots). These Init functions are just tips on the icebergs and you will find yourself quickly in a rabbit hole.
The saner approach is to rewrite the actual PRU driver (however I think it uses constructs like ring buffers, so you probably will have to bend the logic).
7 years 7 months ago #128885 by andypugh
Tower wrote: It's not going to be easy. The HAL engines in both Machinekit and LinuxCNC diverged quite a bit over the years after the fork and now the Machinekit one is quite reworked (with the multicore and instantiable components support, new HAL objects and whatnots). These Init functions are just tips on the icebergs and you will find yourself quickly in a rabbit hole.
Components written with .comp look exactly the same, though. (Not that the BBB drivers fit into that class)
7 years 7 months ago #128894 by andypugh
I asked the hal_pru_generic author for his take on this:
"My guess is it would be dramatically easier to get the hal_pru_generic
driver running on LCNC vs. merging reverse-run into Machinekit."
7 years 7 months ago - 7 years 7 months ago #128898 by OT-CNC
Bosston88
What are you using as a power supply?
Where do we stand on reverse run if not using a beagle bone?
I found this on youtube:
Last edit: 7 years 7 months ago by OT-CNC. Reason: found on youtube
7 years 7 months ago #128963 by Tower
andypugh wrote: Components written with .comp look exactly the same, though. (Not that the BBB drivers fit into that class)
That's true, but COMP is precompiled sublanguage. I think that it's there for backward compatibility reason as it was superseded by the ICOMP (instantiable components) and now is considered pretty much obsolete.
It probably has something to do with Michael Haberler's idea of not differentiating RT/USERSPACE components but RT/nonRT threads (which cannot be done under RTAI).
andypugh wrote: I asked the hal_pru_generic author for his take on this:
Well, that's it then. I would take Charles Steinkuehler opinion. He seems very competent.
BTW, is reverse run branch changing code run in RT threads or it is all in higher parts?
7 years 7 months ago #128964 by andypugh
Tower wrote: BTW, is reverse run branch changing code run in RT threads or it is all in higher parts?
I don't know for sure, but I am pretty sure that reverse-run hooks in to the adaptive feed mechanism, and that is (necessarily) in the realtime layer.
Time to create page: 0.212 seconds
