controlling a HY VFD via RS485, fails to respond
  • travis036
  • Topic Author
  • Elite Member
  • Elite Member
7 years 6 months ago #130601 by travis036
VFD part: HY04D023B
i followed the tutorial from:
i set the VFD parameters as described:
PD001 = 2 (use comm port)
PD002 = 2 (use comm port)
PD163 = 1 (Comm Address)
PD164 = 1 (9600 Baud)
PD165 = 3 (8N1 for RTU)
put the following in custom.hal:
loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600
net spindle-cmd-rpm-abs => vfd.speed-command
net spindle-cw motion.spindle-forward => vfd.spindle-forward
net spindle-ccw motion.spindle-reverse => vfd.spindle-reverse
net on motion.spindle-on => vfd.spindle-on
put the following in custom_postgui.hal:
setp vfd.enable 1
i have verified that the RS485 USB is on /dev/ttyUSB0.
i thank you all in advance for any help.
~Travis
7 years 6 months ago - 7 years 6 months ago #130604 by farmerboy1967
Replied by farmerboy1967 on topic controlling a HY VFD via RS485, fails to respond
Before going too far, check to see if the there is no missing components on the mainboard. Not all of the HY series of VFDs have the necessary components installed on the circuit board for serial communications to work.
[strike] You will need to remove the upper circuit board to clearly see the mainboard. There are Youtube videos of people taking it apart. I made sure mine was populated, even though I'm not using modbus at this time.[/strike]
Sorry, It's been quite a while, but the components should be on the top circuit board. you just have to take the cover off to see it.
EDIT: Go here to see if you have missing parts:
www.machsupport.com/forum/index.php?topi....msg103415#msg103415
[strike] If the components on yours are there, I can't help you, but if yours are missing, from what I have read, the traces are there, they just needs to be populated with the missing components.
I don't know the name of the website off of the top of my head, but there is one that shows how to add the missing components, and the part numbers needed. You will have to Google for it.[/strike]
Last edit: 7 years 6 months ago by farmerboy1967.
  • travis036
  • Topic Author
  • Elite Member
  • Elite Member
7 years 6 months ago #130616 by travis036
Replied by travis036 on topic controlling a HY VFD via RS485, fails to respond
I can verify the necessary RS485 components are installed, and actually, i had it start the spindle via software, but then it stopped communicating, as the spindle reved higher and higher. but then i couldn't get control of it again, via RS485.
i even tried the tips from here: linuxcnc.org/docs/html/man/man1/hy_vfd.1.html
but still no joy.
i have a total of 5 of the RS485 USB adapters, and tried two others, in case of a fail, but no joy.
I can still revert the VFD back to manual control, but it would be so much better to control via software.
~Travis
7 years 6 months ago #130619 by slc
The baud rate for this spindle in my custom.hal file is 19200
I went round in circles for many hours getting this working because of all the variations among the drives.
If you still have no luck I will try and get all the configs tomorrow and post them here.
  • travis036
  • Topic Author
  • Elite Member
  • Elite Member
7 years 6 months ago #130626 by travis036
from my little knowledge of RS485, should i insert a 120Ohm termination resistor into the bus?
I will try it tomorrow, when i get a chance.
~Travis
7 years 6 months ago #130647 by Mike_Eitel
Replied by Mike_Eitel on topic controlling a HY VFD via RS485, fails to respond
Hi Travis
If you have to fight emv use the resistor plus twisted cables, to make it even better use a screened cable and connect screen only on pc side direct to the cubicle with a "fat" connection.
Mike
7 years 6 months ago #130660 by slc
The relevant bits of my custom.hal file
I have no idea if this is correct or how I arrived at it several years ago, but the spindle works with this
loadusr -Wn spindle-vfd hy_vfd -n spindle-vfd -t 1 -d /dev/ttyUSB0 -p none -S24000 -r 19200 -s 1
net spindle-cmd-rpm-abs => spindle-vfd.speed-command
net spindle-cw motion.spindle-forward => spindle-vfd.spindle-forward
net spindle-ccw motion.spindle-reverse => spindle-vfd.spindle-reverse
net on motion.spindle-on => spindle-vfd.spindle-on
  • travis036
  • Topic Author
  • Elite Member
  • Elite Member
7 years 6 months ago #130673 by travis036
it seems to work now, with a variety of changes. i switched to a piece of CAT5e FTP cable (foil twisted pair). set baud to 9600, and changed to a different RS485 adapter. i also inserted a 120Ohm resistor at both ends of the FTP pair in use.
not sure exactly what the single solution is, but they work as a whole. i haven't grounded the FTP foil to the PC yet, but i suspect when i do, it will likely allow me to step up to 19200 baud.
i still have to correct a few parameters in the VFD, regarding the motor (rated RPM @ 50Hz, and number of poles) but it works now via RS485.
~Travis
7 years 6 months ago #130675 by slc
For future reference in case I ever move a machine and have similar problems again , how long is the RS485 cable you use?
  • travis036
  • Topic Author
  • Elite Member
  • Elite Member
7 years 6 months ago #130677 by travis036
i didn't measure it, but i would say about 6 - 8 feet long. i would suspect longer would also work. but i didn't want to go crazy, as the computer, VFD, and CNC, are all currently within 4 feet of each other.
I plan on shielding the rest of the components in the near future, now that the proof-of-concept setup seems to work.
~Travis
Time to create page: 0.153 seconds
