Did we end up getting the new trajectory planner?
7 years 6 months ago #131696 by cmorley
there are limitations. It only uses the new planner if using any/all of the XYZ axes.
If you use any other axes - it reverts back to the default planner.
Chris M
7 years 6 months ago #131708 by lukepighetti
I'm on 2.7.14 right now and the trajectory planner is definitely better than in 2.6. Much thanks to all developers involved in that feature.
7 years 6 months ago #131726 by lukepighetti
Man, this thing really rips. Huge productivity gains.
7 years 5 months ago - 7 years 5 months ago #133435 by 1240
Hi!
Did I should insert in *.ini manually?
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 0
ARC_BLEND_OPTIMIZATION_DEPTH = 50
ARC_BLEND_GAP_CYCLES = 4
ARC_BLEND_RAMP_FREQ = 100
for using new TP?
Last edit: 7 years 5 months ago by 1240.
7 years 5 months ago #133442 by lukepighetti
When I installed 2.7 I got it automatically.
7 years 5 months ago #133450 by Todd Zuercher
I don't think those ini entries are nessisary unless you want to use settings that are not the defaults.
The following user(s) said Thank You: 1240
Time to create page: 0.314 seconds
