Joint limit switch errors
7 years 5 months ago #135030 by PCW
Replied by PCW on topic Joint limit switch errors
Umm it looks like you have a sim config...
from your hal file:
loadrt sim_parport names=parport.0
7 years 5 months ago #135031 by norbertfarquharsh
Thank you very much. I never would have spotted that. Had no idea what that was and looked it up and still have no idea what I would want to use it for and how it got in there.
My first thought is to go through Stepconfig and generate a new set of .hal and .ini. and see if there is anything that I might do or might have done to generate that line and then check if I get a sim_parport line again.
So I will try that, but if you have any suggestions they would be very welcome.
Thanks again.
7 years 5 months ago #135032 by tommylight
On the second page of stepconf there is a selection for "create simulated............", do not check that, or uncheck if it is checked.
7 years 5 months ago #135061 by norbertfarquharsh
Yes, I think I remember that and pretty much ignored it but I may have checked it thinking it was meant something else. I will look at that.
Thanks a lot.
7 years 5 months ago #135067 by norbertfarquharsh
YES, that fixed the problem with the limit switches.
For some reason now I have other problems that I will need to figure out.
Thanks a lot.
7 years 5 months ago #135102 by tommylight
Nice, keep asking and we'll keep answering.
You are welcomed, always.
Time to create page: 0.569 seconds
