can't go to 0, 0, 0 ... by G1 X0 Y0 Z0 F500 .....
7 years 3 months ago #138513 by emilvv
Hello,
When i homed the machine ... and write:
G1 X0 Y0 Z0 F500 ENTER ...
machine can't go to 0, 0, 0 ...
machine starts moving but go to not exactly to 0, 0, 0 ... position .. in example
result is .... 0, -2.5, 4 ......
Please help ... where to check and what to do .....?
I want after ..... G1 X0 Y0 Z0 F500 to go to 0, 0, 0 :)
Best regards,
Emil
7 years 3 months ago #138514 by BigJohnT
You have an offset perhaps...
G53 G0 X0 Y0 Z0 will go to the machine origin.
JT
7 years 3 months ago #138519 by emilvv
Thank you !
How I can remove the offset - maybe INI file change or ?? :)
Regards,
Emil
7 years 3 months ago #138520 by BigJohnT
In the Axis GUI you can do Machine > Zero coordinate system then pick the one with the offset (usually G54 or G92) or read this linuxcnc.org/docs/2.7/html/user/user-con...l#_when_you_are_lost
JT
The following user(s) said Thank You: emilvv
Time to create page: 0.241 seconds
