our sherline cnc machine couldnot working homing conditions
7 years 2 months ago #141177 by nishmal@nhanz.com
DEAR SIR
OUR SHERLINE CNC MACHINE COULD NOT WORKING HOMING CONDITIONS.FIRST I SET PARAMETERS IN LINUX STEP CONFIGURATION
AFTER SET THE VALUES OF HOMING VALUES OF X AND YAXIS IN MANUL CODITION.AFTER THE RUN IN THE PROGRAM
ITS SHOW CANNOT ISSUE MDI COMMAND WHEN NOT HOMED ERROR
THEN HOW DID CORRECT THE ERROR
7 years 2 months ago #141179 by tommylight
7 years 2 months ago #141180 by nishmal@nhanz.com
Home the z axis after that each could not working homing condition
7 years 2 months ago #141488 by verticalperformance
Does the machine have home and/or limit switches? Most Sherline setups do not, and the machine must be configured and homed accordingly.
7 years 2 months ago #141612 by nishmal@nhanz.com
Hi
Thanks for the reply,
My home setting is as below in step config
X-axis Limit+home
y-axis Limit+home
Z-axis Limit+home
I have limit switches connected in series on both ends of X and Y axis and only on top side of Z axis . I am using TB6560 4 axis board.
With this setting on Launch , I am unable to automatic homing,
I am getting the following error
"joint 0 on limit switch error"
But I am able to jog.
If some bode here can sent me a working configuration file it would be very helpful.
7 years 2 months ago - 7 years 2 months ago #141614 by Clive S
Can you post the hal and ini files from the config folder
Also what version of Linucnc are you using
Last edit: 7 years 2 months ago by Clive S.
Time to create page: 0.357 seconds
