Using the parallel port tester that was set up by BigJohnT, I added the modifications in the attached files for a system using 3 parallel ports. ptest.hal was setup for the motherboard port. I modified it by adding the port addresses given by lspci =vv. Since it only will accommodate 12 pins (or one port) at a time, I created ptesttest.txt so it is handy to copy and over write the pin id's in ptest.hal for each port.
File Name:
ptest.hal
File Size:1.68 KB
