New Lathe build encoder index pulse stopped working
- Danimal74
05 Sep 2019 03:27 #144189
by Danimal74
New Lathe build encoder index pulse stopped working was created by Danimal74
I have been designing and building a lathe cnc conversion and want it primarily for threading. I bought a cheap encoder 100ppr that has phase A, phase B and suppose to have an index but it stopped working right after I wired it in and was getting the spindle to work for spindle at speed.
Right now I have encoder.N.counter−mode true and the encoder pulses are reading fine for RPM.
My question is, can I use phase B as the index and scale it like I do the encoder? I don't really need quadrature, so if I could have the 100th pulse trigger the encoder.N.index−enable bit it would prevent needing to buy and install a new one right away. I will probably just buy a new one later on, but for the time being I wanted to keep setting up and testing.
- pl7i92
- Thank you received: 358
05 Sep 2019 06:06 #144206
by pl7i92
Replied by pl7i92 on topic New Lathe build encoder index pulse stopped working
hi
yes
first use a second encoder feed it with the B-Phase counts
you can use a cooperator to reset the encoder and set the Z-phase
as counter comp will be depreced in 2.8 dont use the counter
yes
- Danimal74
05 Sep 2019 14:37 #144240
by Danimal74
Replied by Danimal74 on topic New Lathe build encoder index pulse stopped working
I can set encoder.N.counter−mode false, then point the encoder phase B parallel port pin => encoder.N.index-Z, but I am not sure what you mean by use cooperator to set phase.
I am picturing that the software would think that it was at the same index starting point and it could be at any of 100 different points around the encoder.
- Dinuka_Shehan
- Thank you received: 26
05 Sep 2019 16:59 - 05 Sep 2019 18:37 #144251
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic New Lathe build encoder index pulse stopped working
use a hall effect sensor or magnetic proximity switch as spindle index pulse.
Simple configuration.
I may work.
Moderators may correct me if I am wrong.
I may work.
Last edit: 05 Sep 2019 18:37 by Dinuka_Shehan.
- Dinuka_Shehan
05 Sep 2019 17:04 #144252
by Dinuka_Shehan
- Hakan
- Thank you received: 454
05 Sep 2019 20:01 #144268
by Hakan
Replied by Hakan on topic New Lathe build encoder index pulse stopped working
Danimal74 I think you should somehow only trigger the index-Z every <encoder-scale> pulses, should be once per revolution. There are some different ways to do that with hal components I suppose, thinking of div and mod math operators.
05 Sep 2019 23:38 #144293
Replied by andypugh on topic New Lathe build encoder index pulse stopped working
As was suggested above, just add an extra sensor somewhere that picks up something once-per-rev. This is likely to be more reliable than triggering in HAL.
The HAL solution would get confused by the reverse in the middle of a rigid tap.
- Hakan
06 Sep 2019 06:54 - 06 Sep 2019 06:58 #144329
by Hakan
in some kind of pseudo-code should always give a signal once every turn no matter direction. But I couldn't find a "mod" hal component, so maybe not so easy to implement after all. SHould be no problem in a user component, but the complexity rises (by some).
if abs(encoder.count mod encoder.position-scale) <1 index-Z = 1
Last edit: 06 Sep 2019 06:58 by Hakan.
- Danimal74
08 Sep 2019 23:48 #144556
by Danimal74
Thanks for all the reply's. I just ordered another one and it will be here in a month. I put a cheap hall effect sensor on there for tuning.
The following user(s) said Thank You: Dinuka_Shehan
- Dinuka_Shehan
09 Sep 2019 11:59 #144594
by Dinuka_Shehan
We are hoping that you can continue with new encdoder.cheers
Time to create page: 0.627 seconds
