Programs always exceed positive Z limit at end
- JetForMe
- Thank you received: 27
Any ideas? Thanks!
- Clive S
- Thank you received: 486
I’m just getting my router up and running, using Fusion 360’s generic linuxcnc.cps post processor to post to the machine, and one thing that always happens is at the end of the run, it trips hitting the soft positive Z limit. You can see it in the attached screenshot, which also shows the tail end of the gcode that ran. It runs normally in G54 with z=0 set to the top of work, more than 200 mm below the top of the Z-axis. Going to G53 Z0 should be fine; I can do it manually without tripping things (I think).
Any ideas? Thanks!
Try bringing the soft limit down a bit . It might be overshooting
- Leon82
- Thank you received: 79
Do you have a home offset for homeing?
- Thank you received: 7468
Do you have a G21 at the top of gcode ?
- JetForMe
In gcode you have 15mm, in the screenshot it is at 208mm ? How ? Why ?
Yeah, I've attached the program. The Z15 is in G54, which has z=0 set to the top of work.
- JetForMe
Wouldn't the machine know to slow as it approaches the target position? It does that for all other moves.
- JetForMe
HOME = -5.0
HOME_OFFSET = 5.0
HOME_SEARCH_VEL = 25
HOME_LATCH_VEL = -5
HOME_SEQUENCE = 0
HOME_USE_INDEX = False
HOME_IGNORE_LIMITS = TruePlease Log in or Create an account to join the conversation.
- Clive S
That is all good, but how did you get Z to go up to positive 208mm ? I do not see any offsets active in that screenshot.
- JetForMe
I've attached the full .ini file. I'm pretty sure that's 208 mm in G54.
[AXIS_Z]
MIN_LIMIT = -340.0
MAX_LIMIT = 0.0
MAX_VELOCITY = 200
MAX_ACCELERATION = 1000
[JOINT_3]
AXIS = Z
MIN_LIMIT = -340.0
MAX_LIMIT = 0.0Please Log in or Create an account to join the conversation.
