How to zero coordinates?
07 Nov 2019 01:26 #149786 by Cranktown
How to zero coordinates? was created by Cranktown
I have a linux cnc set up with plasmac
Was wondering if there is a way to zero the coordinates so I can move where the cut is made much like the 'zero coordinates' button in mach3.
And if so, how could I program one of the custom buttons to do this?
Thanks!
07 Nov 2019 01:46 #149787 by Leon82
Replied by Leon82 on topic How to zero coordinates?
You could make an mdi button,
G90 g10 l2 xo yo if I recall. Will write the current position to work offset zero
07 Nov 2019 02:02 #149790 by andypugh
Replied by andypugh on topic How to zero coordinates?
Touch-off should do it. Which GUI are you using?
The following user(s) said Thank You: Cranktown
07 Nov 2019 02:10 #149792 by phillc54
07 Nov 2019 02:18 #149794 by Cranktown
Replied by Cranktown on topic How to zero coordinates?
It says 'p value out of range with g10 l2'
07 Nov 2019 02:20 #149795 by Cranktown
Using gmoccapy, when I try to touch off it says something along the lines of "cant touch off with none or more than one tool selected" (theres only one tool in the table and it is selected) haha
07 Nov 2019 02:21 #149796 by Leon82
Add a p1. I havent done in a. While
07 Nov 2019 02:35 #149798 by phillc54
Replied by phillc54 on topic How to zero coordinates?
Are you using this button:
then these buttons:
07 Nov 2019 03:07 #149800 by Cranktown
None of those, I was trying to use the touch off in the tooleditor page
07 Nov 2019 03:10 #149801 by phillc54
For the PlasmaC config you need to use the above ones, not the tool touchoff.
