Calculating path length
6 years 11 months ago #151318 by newbynobi
Replied by newbynobi on topic Calculating path length
Look at machine kit, they are controlling 3D printers. The extrusion velocity must depend on axis velocity, as otherwise you do have more material at all directions changing, due to acceleration issues.
May be the code from machine kit solve your issue.
Norbert
6 years 10 months ago #151757 by andypugh
Replied by andypugh on topic Calculating path length
An wrote: Thanks for the replies guys. Im still unclear as to whether i can do this the way i want to using the kins file
Possibly, but the solution from PCW is 2 lines of HAL and needs no coding. Why not use that?
Time to create page: 0.283 seconds
