Python script ImportError: No module named 'linuxcnc'
5 years 9 months ago #193934 by frequency
I created an .xsessionrc file in my home folder with the output of
$ source rip-environment
without the first lines after the lines of the QtPyVCP installation script:
# added py QtPyVCP install script
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
#From here downwards
EMC2_HOME=/home/cnc-pc/linuxcnc; export EMC2_HOME
EMC2VERSION="2.8.1"; export EMC2VERSION
LINUXCNCVERSION="2.8.1"; export LINUXCNCVERSION
LINUXCNC_NCFILES_DIR="/home/cnc-pc/linuxcnc/nc_files"; export LINUXCNC_NCFILES_DIR
LINUXCNC_EMCSH=/usr/bin/wish8.6; export LINUXCNC_EMCSH
PATH=/home/cnc-pc/linuxcnc/bin:$EMC2_HOME/scripts:$EMC2_HOME/tcl:"$PATH"
if [ -z "$TCLLIBPATH" ]; then
TCLLIBPATH=$EMC2_HOME/tcl
else
TCLLIBPATH=$EMC2_HOME/tcl:$TCLLIBPATH
fi
if [ -z "$LD_LIBRARY_PATH" ]; then
LD_LIBRARY_PATH=$EMC2_HOME/lib
else
LD_LIBRARY_PATH=$EMC2_HOME/lib:"$LD_LIBRARY_PATH"
fi
if [ -z "$PYTHONPATH" ]; then
PYTHONPATH=$EMC2_HOME/lib/python
else
PYTHONPATH=$EMC2_HOME/lib/python:"$PYTHONPATH"
fi
if [ -z "$MANPATH" ]; then
if type -path manpath > /dev/null 2>&1; then
MANPATH=$EMC2_HOME/docs/man:"$(manpath)"
else
MANPATH=$EMC2_HOME/docs/man:/usr/local/man:/usr/local/share/man:/usr/share/man
fi
else
MANPATH=$EMC2_HOME/docs/man:"$MANPATH"
fi
if [ -z "$GLADE_CATALOG_PATH" ]; then
GLADE_CATALOG_PATH=$EMC2_HOME/lib/python/gladevcp
else
GLADE_CATALOG_PATH=$EMC2_HOME/lib/python/gladevcp:"$GLADE_CATALOG_PATH"
fi
if ! $as_command; then
# TODO: if these completion directives give trouble for any versions
# of bash actively in use, protect them with checks of BASH_VERSINFO
if [ $BASH_VERSINFO -eq 2 ]; then
complete -o dirnames -f -X '!*.ini' emc axis mdi
complete -o dirnames -f -X '!*.hal' halrun halcmd
complete -W 'start stop restart status' realtime
complete -C "halcmd -C" halcmd
else
_iningc () {
case "$3" in
*.ini) COMPREPLY=($(compgen -o plusdirs -f -X '!*.ngc' -- "$2")) ;;
*) COMPREPLY=($(compgen -o plusdirs -f -X '!*.ini' -- "$2"))
esac
complete -o plusdirs -F _iningc emc axis
complete -o plusdirs -f -X '!*.ini' mdi
complete -o plusdirs -f -X '!*.hal' halrun halcmd
fi
if [ -f $EMC2_HOME/src/Makefile ]; then
build () { make -C $EMC2_HOME/src "$@"; }
fi
fi
export PYTHONPATH MANPATH LD_LIBRARY_PATH TCLLIBPATH GLADE_CATALOG_PATH
if $as_command; then exec "$@"; fi
Time to create page: 0.196 seconds
