Linux Mint 19.3 + Signed RT Kernel failed + UEFI-Bios
  • Weiler810T
  • Weiler810T's Avatar Topic Author
  • Visitor
  • Visitor
07 Dec 2019 10:36 - 07 Dec 2019 10:46 #152227 by Weiler810T
Hello
I'm playing around with Mint 19.3 and want to install Linuxcnc. It fails because of a signed RT kernel.
Compile running but not signed for UEFI-bios.
Any ideas?
Howto for signed RT-Kernel? ;)
Bootmenue
Hardware
chiron@chiron-SystemFZ16:~$ halcompile
halcompile: Befehl nicht gefunden.
chiron@chiron-SystemFZ16:~$ inxi -Fz
System:
  Host: chiron-SystemFZ16 Kernel: 5.3.0-24-lowlatency x86_64 bits: 64
  Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
Machine:
  Type: Desktop Mobo: ASUSTeK model: TUF Z390-PRO GAMING v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 2417 date: 06/03/2019
CPU:
  Topology: 8-Core model: Intel Core i7-9700KF bits: 64 type: MCP
  L2 cache: 12.0 MiB
  Speed: 801 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics:
  Device-1: NVIDIA GP107GL [Quadro P1000] driver: nouveau v: kernel
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 3840x2160~60Hz
  OpenGL: renderer: NV137 v: 4.3 Mesa 19.0.8
Audio:
  Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
  Sound Server: ALSA v: k5.3.0-24-lowlatency
Network:
  Device-1: Intel Ethernet I219-V driver: e1000e
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 2.73 TiB used: 91.98 GiB (3.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
  ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
  ID-3: /dev/sdb type: USB vendor: Seagate model: ST2000LM007-1R8174
Partition:
  ID-1: / size: 456.96 GiB used: 62.74 GiB (13.7%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 41 C
  Fan Speeds (RPM): cpu: 0 gpu: nouveau fan: 1721
Info:
  Processes: 268 Uptime: 25m Memory: 31.28 GiB used: 1.29 GiB (4.1%)
  Shell: bash inxi: 3.0.32
Last edit: 07 Dec 2019 10:46 by Weiler810T.
  • Moderator
  • Moderator
07 Dec 2019 11:36 #152232 by tommylight
  • Weiler810T
  • Visitor
  • Visitor
07 Dec 2019 13:07 #152242 by Weiler810T
hello Tommy
doesn't work, unsigned kernel :silly:
hmmm...
07 Dec 2019 14:51 #152254 by PCW
Can you disable secure boot in your BIOS?
  • Weiler810T
  • Visitor
  • Visitor
07 Dec 2019 14:56 #152256 by Weiler810T
No, you can sign the kernel yourself, no idea how it works with sbsign, you have to make me smart first ;)
chiron@chiron-SystemFZ16:~$ sbsign
Usage: sbsign [options] --key <keyfile> --cert <certfile> <efi-boot-image>
Sign an EFI boot image for use with secure boot.
Options:
	--key <keyfile>    signing key (PEM-encoded RSA private key)
	--cert <certfile>  certificate (x509 certificate)
	--detached         write a detached signature, instead of
	                    a signed binary
	--output <file>    write signed data to <file>
	                    (default <efi-boot-image>.signed,
	                    or <efi-boot-image>.pk7 for detached
	                    signatures)
chiron@chiron-SystemFZ16:~$ sudo update-secureboot-policy --enroll-key
[sudo] Passwort für chiron:
Das hat nicht funktioniert, bitte nochmal probieren.
No DKMS modules installed.
chiron@chiron-SystemFZ16:~$ kmodsign sha512 \
>     /var/lib/shim-signed/mok/MOK.priv \
>     /var/lib/shim-signed/mok/MOK.der \
>     module.ko
At main.c:248:
- SSL error:0200100D:system library:fopen:Permission denied: ../crypto/bio/bss_file.c:72
- SSL error:2006D002:BIO routines:BIO_new_file:system lib: ../crypto/bio/bss_file.c:81
kmodsign: /var/lib/shim-signed/mok/MOK.priv: Permission denied
chiron@chiron-SystemFZ16:~$ bootctl status
System:
     Firmware: n/a (n/a)
  Secure Boot: enabled
   Setup Mode: user
Current Loader:
      Product: n/a
          ESP: n/a
         File: └─n/a
Boot Loader Entries in EFI Variables:
        Title: ubuntu
       Status: active, boot-order
    Partition: /dev/disk/by-partuuid/78c218fe-ad21-4d06-8f51-49f60788bce8
         File: └─/EFI/UBUNTU/SHIMX64.EFI
        Title: Windows Boot Manager
    Partition: /dev/disk/by-partuuid/59227b98-689c-4ffd-93c0-cba35beb987f
         File: └─/EFI/MICROSOFT/BOOT/BOOTMGFW.EFI
        Title: debian
         File: └─/EFI/DEBIAN/GRUBX64.EFI
        Title: ubuntu
chiron@chiron-SystemFZ16:~$ mok-util
Der Befehl 'mok-util' wurde nicht gefunden, meinten Sie:
  Befehl 'mokutil' aus dem deb mokutil
Versuche: sudo apt install <deb name>
chiron@chiron-SystemFZ16:~$ sudo apt install mokutil
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
mokutil ist schon die neueste Version (0.3.0+1538710437.fb6250f-0ubuntu2~18.04.1).
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
  libgladeui-2-6 libgladeui-common
Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
chiron@chiron-SystemFZ16:~$ sudo apt autoremove
Die folgenden Pakete werden ENTFERNT:
0 aktualisiert, 0 neu installiert, 2 zu entfernen und 0 nicht aktualisiert.
Nach dieser Operation werden 8.936 kB Plattenplatz freigegeben.
Möchten Sie fortfahren? [J/n] j
(Lese Datenbank ... 507063 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von libgladeui-2-6:amd64 (3.22.1-1) ...
Entfernen von libgladeui-common (3.22.1-1) ...
Trigger für libc-bin (2.27-3ubuntu1) werden verarbeitet ...
chiron@chiron-SystemFZ16:~$ mokutil
Usage:
  mokutil OPTIONS [ARGS...]
Options:
  --help				Show help
  --list-enrolled			List the enrolled keys
  --list-new				List the keys to be enrolled
  --list-delete				List the keys to be deleted
  --import <der file...>		Import keys
  --delete <der file...>		Delete specific keys
  --revoke-import			Revoke the import request
  --revoke-delete			Revoke the delete request
  --export				Export keys to files
  --password				Set MOK password
  --clear-password			Clear MOK password
  --disable-validation			Disable signature validation
  --enable-validation			Enable signature validation
  --sb-state				Show SecureBoot State
  --test-key <der file>			Test if the key is enrolled or not
  --reset				Reset MOK list
  --generate-hash[=password]		Generate the password hash
  --ignore-db				Ignore DB for validation
  --use-db				Use DB for validation
  --import-hash <hash>			Import a hash into MOK or MOKX
  --delete-hash <hash>			Delete a hash in MOK or MOKX
  --set-verbosity <true/false>		Set the verbosity bit for shim
  --pk					List the keys in PK
  --kek					List the keys in KEK
  --db					List the keys in db
  --dbx					List the keys in dbx
  --timeout <-1,0..0x7fff>		Set the timeout for MOK prompt
Supplimentary Options:
  --hash-file <hash file>		Use the specific password hash
  --root-pw				Use the root password
  --simple-hash				Use the old password hash method
  --mokx				Manipulate the MOK blacklist
chiron@chiron-SystemFZ16:~$ mokutil --pk
[key 1]
SHA1 Fingerprint: ec:d9:88:46:2e:bc:25:e7:ee:a7:91:72:08:9e:f3:fd:d1:b0:24:97
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            53:41:e0:15:c4:3a:f8:a8:48:36:b9:a5:ff:69:14:88
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: CN=ASUSTeK MotherBoard PK Certificate
        Validity
            Not Before: Dec 26 23:34:50 2011 GMT
            Not After : Dec 26 23:34:49 2031 GMT
        Subject: CN=ASUSTeK MotherBoard PK Certificate
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                RSA Public-Key: (2048 bit)
                Modulus:
                    00:d9:84:15:36:c5:d4:ce:8a:a1:56:16:a0:e8:74:
                    cd:58:1e:2a:02:96:1b:c4:37:64:da:8c:6a:24:84:
                    cd:dc:c4:68:04:15:c7:e9:cf:20:a4:45:1a:42:f0:
                    a3:9b:62:22:6e:2a:43:67:17:8d:4d:10:aa:f8:dd:
                    f2:2a:9e:86:ba:91:d0:32:7e:95:be:01:78:73:3a:
                    d3:98:7e:19:f8:16:0e:27:cc:ea:c5:be:b5:80:7e:
                    e8:bc:a8:17:41:b3:ea:55:34:19:53:d7:7e:7d:50:
                    c7:5a:b8:ef:54:f9:13:6e:ab:d6:45:cd:1d:02:94:
                    e2:78:d7:88:a8:10:52:8d:7e:ba:f1:49:36:c0:68:
                    70:f9:d5:0c:5a:fd:6b:1a:6f:88:c2:37:69:22:42:
                    92:f3:9d:ae:ef:73:ec:f4:0f:32:42:64:c3:e9:b9:
                    89:dd:06:e5:cc:2f:6b:f8:00:4e:91:64:f7:03:45:
                    f0:4f:a4:11:83:e9:83:97:e9:a0:dc:2d:c8:03:56:
                    b4:df:61:a6:32:a5:8b:a6:1b:4e:d8:1c:a7:a3:f3:
                    72:4e:72:f8:fe:69:49:cf:61:f2:e6:59:96:58:b8:
                    14:7c:ca:f5:e5:6b:f0:6d:da:f7:bc:08:5b:7f:57:
                    e9:96:37:59:5a:70:79:57:0e:c8:82:c8:91:7b:67:
                    f9:2d
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            2.5.29.1:
?=.../0-1+0)..U..."ASUSTeK MotherBoard PK Certificate..SA...:..H6...i..
         73:27:1a:32:88:0e:db:13:8d:f5:7e:fc:94:f2:1a:27:6b:c2:
         ca:79:d0:ba:b6:58:bc:df:97:13:5a:4c:dc:a2:e4:90:39:7b:
         24:84:7d:2e:a3:95:96:39:a6:6b:c2:a6:51:38:6f:e5:0b:af:
         c0:91:0a:90:3f:3e:5a:e4:79:16:98:96:32:94:49:ae:00:28:
         18:aa:ef:fb:54:95:93:c7:fc:e4:89:ef:96:00:ce:d6:c6:8a:
         4d:85:ca:9c:6c:fb:8a:a7:43:60:36:5e:73:97:17:2f:16:46:
         d0:ce:f0:a0:07:77:62:4d:15:0e:22:f6:91:71:1a:79:e1:85:
         1c:0b:2c:94:9f:9d:97:cf:49:b5:dd:ea:6a:e5:a7:61:ec:82:
         0d:95:e8:98:5c:e8:72:c6:da:8d:df:21:ec:05:30:0f:79:b8:
         af:e9:b0:2b:c0:83:73:fe:bf:9d:4a:6d:da:a5:a0:65:37:cf:
         2c:87:f1:2b:c6:a3:0e:92:64:57:1a:77:ed:d9:47:40:47:da:
         ea:ff:23:98:d1:25:b9:72:f5:38:3a:b3:33:a5:5d:f1:44:dc:
         d8:63:7d:f9:2f:7d:f1:d1:d0:95:c0:a6:75:a8:70:c9:c4:2b:
         c0:45:04:d0:40:5b:75:7d:e2:b2:0a:3c:1e:64:22:30:d2:02:
         84:c5:b7:bb
Options:
	                    a signed binary
	                    signatures)
07 Dec 2019 15:01 - 07 Dec 2019 15:01 #152257 by PCW
Seems like a lot of trouble (and something would have to be redone every time you updated a kernel module)
If It were my choice I would recycle any PC that doesn't allow you to disable secure boot
Last edit: 07 Dec 2019 15:01 by PCW.
  • Weiler810T
  • Visitor
  • Visitor
07 Dec 2019 15:52 #152263 by Weiler810T
:lol: :lol: :lol:
  • Moderator
  • Moderator
07 Dec 2019 20:29 #152284 by tommylight
hello Tommy
hmmm...
That is still 5.2....something kernel, did you try the one linked on the link i linked to ?
And i agree with PCW, secure boot has nothing secure in it and UEFI is the biggest mistake in computer history. It was done solely for the purpose of enabling Microsoft and disabling everything else. Luckily it does not work as intended so we can continue to use Linux.
  • Weiler810T
  • Visitor
  • Visitor
07 Dec 2019 21:05 #152290 by Weiler810T
I see it the same way, but i need windos for cad and the image linked by you has the same proplem.
I can install all dependencies for linuxcnc, but the fucking unsigned kernel doesn't work.
  • Moderator
  • Moderator
07 Dec 2019 21:37 #152297 by tommylight
there is a link for an unsigned kernel there and it does work always, last i installed was 5 days ago.
Time to create page: 3.237 seconds
