E-Stop
6 years 9 months ago #155283 by curtisa
Replied by curtisa on topic E-Stop
Odd, I would've thought that was a valid net expression. Try restoring the following line back in near the top:
net charge-pump <= charge-pump.out
And restoring parallel port pin 17:
net charge-pump => parport.0.pin-17-out
6 years 9 months ago #155285 by PCW
Replied by PCW on topic E-Stop
The first token after the net command must be a signal, not a pin
( charge-pump.out is a pin )
The following user(s) said Thank You: curtisa
Time to create page: 0.162 seconds
