- Thank you received: 96
Invert Stepper Direction in PNCconf
- AgentWD40
- Topic Author
Finally I had to manually edit the ini file and make the step scale negative on that joint to get inverted rotation. I'm up and running, but I'd just like to know if there is a way to accomplish this in pncconf without hand editing?... Or rather I'd just like to know why the first attempt doesn't work.
Also, it seems that pncconf doesn't allow inputting negative values for stepper scale, why not?
image missing https://i.imgur.com/buD2SqS.png
- Leon82
- Thank you received: 79
Big John also has a tool but you cannot Inver the pins from it. Sometimes manual edits are needed
- AgentWD40
- Topic Author
Leon82 wrote: Maybe it assumes a gantry would be the same direction?
I'm inexperienced with cnc, for sure. But with what I've seen in just my off handed research I would have guessed most tandem joints would run in opposite directions. Is that not the case?
- Leon82
- Thank you received: 2181
In pncconf, on the tb1/tb2 tab where I select stepgens, I checked "inv" on the tandem motors "Dir gen B" pin assuming that would invert it's direction. That didn't work as expected. Am I missing something here?
testing 2.8 (without hardware) i see that pncconf does add the code to invert the GPIO that should be the stepper direction output - but maybe it is the wrong GPIO - maybe Peter could confirm the numbering...
negative scales should be possible but yes I see it's not accepted - Ill see to fixing that soon.
Chris
It will negate the scale when checked
- Thank you received: 5334
Chris
In 2.8 and beyond its probably better to invert stepgen/pwmgen etc outputs
using the pin aliases so the configuration program does not need to know the
GPIO mapping:
setp hm2_7i96.0.stepgen.00.direction.invert_output true
- AgentWD40
- Topic Author
cmorley wrote: actually on the motor page there is a checkbox for motor direction (bottom left)
Oh I didn't notice that before, thank you for pointing that out.
But for the case of tandem joints turning in opposite directions, is there a way for pncconf to configure that without the user needing to get into the config files them selves? Should it have been enough to check the "Inv" option on the dir stepgen or was there something else I needed to do?
Chris
