- Thank you received: 8
Hytek wrote: This brings me to a couple of questions. The 5i25 & 7i76 have internal or external 5v options. Are there pros n cons to either?
requires 2 shielded twisted pair + 4 more wires. This combination is not available in a single cable as standard.
Can anyone suggest suitable alternative to this cable?
I just had a more careful look at the cable I have, and found that it is LAPP 6XF8008-00277131
So has 3 of 2x0.14 individually screened twisted pairs, + 4 x 0.1 + 2 x 0.5 cables.
There is a list here:
lapplimited.lappgroup.com/products/onlin...ndard-6fx-8plus.html
Have a look on eBay, there are often remnants available by the metre.
Hytek wrote: Just a quick message to share my fix for the stiff cable issue. I basically designed & 3d printed up some new backshells for the D-sub 25 connectors. If someone can tell me how to add .stl file, I will add them in case these are of use to anyone else
