Linux Newb
Thanks again.
Below in red some explanations, so it should be easier to figure out what to change.
Other stuff is self explanatory.stubb21 wrote: Thank you all for the replies. Sorry I don't know linux at all, I only use it to run the machine. Is this what you're looking for? I don't see a .ini file
# Generated by stepconf at Sat Feb 23 21:15:41 2013
# overwritten when you run stepconf again
[EMC]
MACHINE = Joe
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 0.1
PROGRAM_PREFIX = /home/emc2/emc2/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
PYVCP = custompanel.xml
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = emc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 20833 Make this 100000 just to avoid some latency/cheap drive issues
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = Joe.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.675
MAX_LINEAR_VELOCITY = 2.0 This should be the max velocity in seconds for the machine
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = .675 This should be the max velocity in seconds for this axis, change also for other axis
MAX_ACCELERATION = 10.0 If you need to change this, you will have to change below also
STEPGEN_MAXACCEL = 12.5
SCALE = 16000.0 This should be the scale, or how many pulses to send per inch of movement
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.0
SCALE = 16000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 6.0
MAX_VELOCITY = 0.4
MAX_ACCELERATION = 5.0
STEPGEN_MAXACCEL = 6.25
SCALE = 16000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 6.0
- Thank you received: 1480
As far as MAX_LINEAR_VELOCITY and SCALE I don't know what those are or if I should even mess with them. I bought this machine used so I don't know all the specs that went into building it.
Yes and yes.stubb21 wrote: So if I want to increase my top end feed rate and cutting speed I would just increase max_velocity right? Guessing Axis 0 is X, 1 is Y and 2 is Z?
MAX_LINEAR_VELOCITY is the maximum speed the Machine can travel, meaning the combination of speeds of 2 or more axis moving at the same time, example:
When jogging or moving X and Y at the same time, the head is moving diagonally at a faster speed than any one of it's axis.
SCALE should be the steps needed to move an axis 1 inch, so the motor does 200 steps per rotation, if that motor is directly mounted to a ball screw with a pitch of 5mm, that gives us 40 steps per mm. You will have to also factor in microstepping and/or reduction, or belt teeth on the driving pulley, or the rack/pinion pitch. Sorry i can not be more helpful about this but i never use calculators or any kind of help with the scale as i calculate all in my head very quickly, or when i have unknowns i just enter something and then use the Calibration menu to do the fine tuning.
