2.7.15
12 Feb 2020 11:51 #157165 by jazial
2.7.15 was created by jazial
Hello,
I've upgraded to 2.7.15 and path is not accurate
Slots are not straight
Circles are oval
Downgraded to 2.7.14 and everything is fine
maybe some bug in release, or do I have to tune something ?
  • Moderator
  • Moderator
12 Feb 2020 11:58 #157167 by tommylight
Replied by tommylight on topic 2.7.15
Add G64 P0.1 to the gcode file for mm machine or
G64 P0.01 for imperial
the 0.1 or 0.01 is the actual distance that the machine is allowed to stray off the path.
12 Feb 2020 12:07 #157170 by jazial
Replied by jazial on topic 2.7.15
Here is the program beginning
G21 G40 G49 G64 P0.05
G17
G54
T28 M6
G43 H28
G0 Z78.000
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
26 Feb 2020 22:25 #158578 by andypugh
Replied by andypugh on topic 2.7.15
Hello,
Circles are oval
Are you using exactly the same config files in each case, or did you re-create your configs?
Release notes are here: github.com/LinuxCNC/linuxcnc/blob/ba122d...a8c/debian/changelog
26 Feb 2020 23:22 #158580 by PCW
Replied by PCW on topic 2.7.15
Can you post your hal/ini files?
A PID component change could be the cause of this error
27 Feb 2020 08:45 #158604 by jazial
I've just upgraded.
The only change is linuxcnc version from 2.7.14 to 2.7.15
27 Feb 2020 08:50 #158605 by jazial
Here are the files
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
27 Feb 2020 10:13 - 27 Feb 2020 10:13 #158614 by andypugh
So, it's an analogue servo system, so the problem could be this:
* pid: use command-deriv when supplied
In fact, I see this in your HAL:
net x-vel-cmd       =>  pid.x.command-deriv
But it seems that you might have an error in your HAL as there is nothing driving that signal elsewhere in the HAL. so the velocity command will always be zero and your FF1 term will be ineffective.
So, possibly, an error in your HAL has been masked by a bug in LinuxCNC.
If you comment-out the pid.L.command-deriv lines then you should be back where you were.
Better might be to leave those lines in and add
net L-vel-cmd  axis.N.joint−vel−cmd
for each axis. But that might require some re-tuning of the FF1 PID terms.
The explanation here is that the PID component was meant to calculate velocity command internally if the pin was not connected, and use the supplied value if it was. But it was always calculating it internally. This took some time to be noticed, as it works nearly the same.
Last edit: 27 Feb 2020 10:13 by andypugh.
27 Feb 2020 10:39 #158617 by jazial
I will try
If a bug fix an error, is it still a bug ? ;-)
27 Feb 2020 12:41 #158627 by bbsr_5a
Replied by bbsr_5a on topic 2.7.15
many now did run in this problem as i see in the last 14days
so it needs to be fixed as quick as posible in the Master and buildbot
Time to create page: 0.615 seconds
