6 years 7 months ago #159173
by jazial
Hello,
some time today to try to update the machine
I've added :
# --- added for 2.7.15
net x-vel-cmd <= axis.0.joint−vel−cmd
but halfile is not interpreted after this line (all signals after this one are ignored)
In Hal viewer, net x-vel-cmd is only connected to pid.x.command-deriv
I've added :
6 years 7 months ago #159186
by jazial
Here is the error
what I don't understand is the line
is working, so the axis.0.xxx pins are available
twopass: Error in file ./my_LinuxCNC_machine.hal:
Pin 'axis.0.joint−vel−cmd' does not exist
net x-pos-fb => axis.0.motor-pos-fb
6 years 7 months ago #159189
The pin shows up in the docs for 2.7.
But... I think that the dashes in your
look to be longer than in your
Is it possible that your text editor has inserted an em-dash rather than a minus sign?
axis.0.motor-pos-fb
Time to create page: 0.050 seconds
