Converting RamillXLT mill
6 years 8 months ago - 6 years 8 months ago #158546 by Eggman
Picked up a RamillXLT cnc mill last summer. Over this winter, the memory board failed and will not retain any settings. I ordered a 7i77D and a 7i92M to facilitate a swap from the old, outdated anilam system to a LinuxCNC based system. Have been reading a lot on this board on the different swaps. I'm planning on keeping the servo motors and the cards.
One question I do have, is where does the 10 vdc power come from. All I've seen is 24 and 5 volt supplies.
Thanks.
Eggman.
Last edit: 6 years 8 months ago by Eggman. Reason: Added pic
6 years 8 months ago #158548 by tommylight
Eggman wrote: One question I do have, is where does the 10 vdc power come from. All I've seen is 24 and 5 volt supplies.
If you mean the analogue output from 7i77, then Mesa has it's own voltage converters as that output needs to be from -10V to +10V.
6 years 8 months ago #158549 by Eggman
Replied by Eggman on topic Converting RamillXLT mill
Ok, that makes sense. I guess I was looking for a more complicated solution. Going to have to remember to keep it as simple as I can, though knowing it'll probably get tougher as I go.
6 years 8 months ago #158551 by tommylight
For a day or two ( or a week :) ) it will look to complicated, head will hurt, to many things creating to many new questions, etc etc. After a while the brain gives up, and then that magic moment comes when you realize the shear possibilities of Linuxcnc. From then on, it's more reading, more options to consider, and slowly it becomes clear how easy it is to put things together.
It is a process, for sure.
3 years 9 months ago - 3 years 9 months ago #263231 by Eggman
Yep, a bit slow at getting this done.  Been working out of town here and there, so the mill wasn't a top priority.  Had the contactor wired so I could still use it for rough milling...no increment marks on the handles.
Update:  I have the 7i77 and the 7i92M cards from Mesa.  Since the 7i92M is an ethernet card, I joined the two cards together without the printer cord between them.  Will be transferring the mounting pattern to the panel to mount them.  Removed the un-necessary items from the controller cabinet along with the extra wires going from the computer cabinet to the controller cabinet.  Removed the Anilam monitor and wires from it's head banging perch.
Now for the questions:
1:  Since removing the relay board, PCB801, do I still need to include 3 or 4 relays for the servos in the upgrade?
2:  With the removal or the PCB833 I'll need to connect some of the wires from it to the 7i77?  I'm looking at the P5, P7, P8, and P9       connectors to the correct servo terminal blocks on the 7i77?
3:  Where is a good place to get the bleed resistor for the large blue cap?  Seems I broke an end wire from it.
4:  Is the Auto/Manual switch still utilized?
Thanks.
Last edit: 3 years 9 months ago by Eggman. Reason: Presentation
3 years 9 months ago #263439 by Eggman
Questions:
5. PCB801 relay board, connector P2 has a green wire goes to ground and a blue wire that goes to terminal 6 on the drive boards. Would this be the wire that needs to be grounded to enable the servos to work?
6. Are all of the cable shields from the servos to be connected to grounds on the panel?
7. When using the 7i92 ethernet board, will the board get it's power from the ethernet cable? Or do I need to get 5v from somewhere else?
Thanks.
Time to create page: 0.199 seconds
