How can i run a program on my plasma and control the z axis separately/manually
6 years 8 months ago #158865
by jody0048
How can i run a program on my plasma and control the z axis separately/manually was created by jody0048
How can i run a program on my plasma Table and control the z axis separately/manually - where i can raise it up and down on screen - as a thc would
- thefabricator03
6 years 8 months ago #158869
by thefabricator03
Replied by thefabricator03 on topic How can i run a program on my plasma and control the z axis separately/manually
Do you just mean how to jog the Z axis?
6 years 8 months ago #158876
Replied by tommylight on topic How can i run a program on my plasma and control the z axis separately/manually
He needs moving the Z axis while it is cutting.
On the old config you could add two momentary buttons connected to the parallel port inputs.
For PlasmaC, maybe something can be done with hal/pyvcp or similar.
The following user(s) said Thank You: jody0048
6 years 8 months ago #158878
by phillc54
Replied by phillc54 on topic How can i run a program on my plasma and control the z axis separately/manually
I think you could sorta do that with the height override. Maybe...
Tom, would that be a worthwhile addition?
6 years 8 months ago #158880
That can be done in any normal config, or it is already in the thc_toma config with the benefit of probing for the material.
THC configs should be just that, THC configs.
On the other hand, adding two buttons and the hal lines should not be that hard for him.
Not by any stretch.phillc54 wrote: I think you could sorta do that with the height override. Maybe...
Time to create page: 0.196 seconds
