Sharp 90* turn in gcode becomes a large sweeping turn
6 years 7 months ago - 6 years 7 months ago #159591 by lumberjack_jeff
I am having a similar problem on my 4x8 gantry router. The part in the attached photo was cut using G64 P0.001 in the gcode. Obviously the interpreter didn't respect that tolerance.
The only change I recently made to my configuration is to comment out the lines on backlash compensation.
I suspect my issue is related to acceleration values, but I'd like some advice. Assuming machine units of inches, what are typical acceleration values? From memory, I think I'm at max_acceleration = 12 and stepgen_maxaccel = 18. From reading the documentation, it looks like my maxaccel should be reduced or acceleration be increased.
Last edit: 6 years 7 months ago by lumberjack_jeff.
6 years 7 months ago #159592 by PCW
If you have g64 p .001 this should not be possible without some other errors
Are you sure you dont have another g64 command embedded in your gcode?
another possibility is some hal/ini setup error that is generating a large following error
Can you post you hal/ini files?
BTW 12 ips/s is _very_ slow acceleration for a router = .0313 G
6 years 7 months ago #159596 by lumberjack_jeff
There is only one g64 command and no g61 in the code.
6 years 7 months ago #159597 by PCW
What version of LinuxCNC?
6 years 7 months ago #159598 by lumberjack_jeff
6 years 7 months ago #159602 by PCW
can you post your gcode or a portion of it that exhibits this issue?
Time to create page: 0.439 seconds
