Puma560 - Geometry and building other 6 axis robots
6 years 7 months ago #162357 by dgarrett
@Aciera re: ini hal pins
Is there a way to alter the min- and max-axis limits
ini hal pins are available for both JOINT_N and AXIS_L
MIN_LIMIT,MAX_LIMIT,MAX_ACCELERATION, MAX_VELOCITY
See the milltask man page (especially notes at bottom):
linuxcnc.org/docs/master/html/man/man1/milltask.1.html
In general, an interp-motion sync is needed for ini hal pins
to be recognized for subsequent motion but the sync is
needed to switch kins types anyway.
Recent dgarr/s_kins docs (not commited yet):
www.panix.com/~dgarrett/stuff/switchkins.html
See 3.3 Inifile Limit settings
And intree examples for M128,...:
github.com/LinuxCNC/linuxcnc/blob/dgarr/...ach/puma/mcodes/M128
6 years 6 months ago #163202 by dgarrett
@Aciera
I converted your pdf to the asciidoc format used for
LinuxCNC docs and made a branch dgarr/dhtxt for test.
Ref: github.com/LinuxCNC/linuxcnc/blob/dgarr/...on/dh-parameters.txt
Rendered in html:
www.panix.com/~dgarrett/stuff/dh-parameters.html
The dh-parameters.txt file includes your images from the
pdf but would benefit from some introductory and explanatory
text. If interested, please review the document and
supply any additional text to me.
The easiest way is to send an edited copy of the
dh-parameters.txt file to me:
d g a r r e t t at panix dot com
Time to create page: 0.054 seconds
