Joint error messages
6 years 7 months ago #162278 by Chipmunk
I get a error message at the start of the program advising me that joint 0 which I think is the Z axis exceeds the positive direction and joint 1 which I assume is the Y axis exceeds the positive direction. I have rechecked my homing and also the travel . I have sufficient travel in the positive and the negative direction for all of the axeses. Any thought Please.
6 years 7 months ago #162281 by MovT
Replied by MovT on topic Joint error messages
Post the Program and your ini file. So we can stop guessing.
Best,
Udo
6 years 7 months ago #162285 by Chipmunk
Replied by Chipmunk on topic Joint error messages
Thank you for getting back to me so quickly . I do not know what you mean regarding the Ini file . The ngc file is developed using Cut2d and the execution program is EMC2 , 2.4.6
6 years 7 months ago #162286 by Clive S
Replied by Clive S on topic Joint error messages
Chipmunk wrote: Thank you for getting back to me so quickly . I do not know what you mean regarding the Ini file . The ngc file is developed using Cut2d and the execution program is EMC2 , 2.4.6
The HAL and INI files will be in the Linuxcnc config folder
6 years 7 months ago #162292 by Chipmunk
Thanks for the reply I will be at the machine tomorrow and I will dig that info out.
6 years 7 months ago #162377 by Chipmunk
Hello Linux I think I found the problem but I will need to reconfigure my travel X,Y,Z travel in Stepcon,.My machine is a Taig with a 16 inch bed For some reason my Stepcon settings have changed. The settings for the machine should be x, 12 in, it is at 8 ,.Y should be 5.5 ïn, and it is also at 8 and Z should be 6 in but it shows up as-4. I will change these settings to what they should be and try again. In trying to test the settings in Devcon I can't seem to get the test button to work . Have you any suggestions.? One other question, I have downloaded Wheezy and am running it on a separate machine. I went into Defcon but it does not support Taig. It supports Sherline could i use that to set up the Taig? Thank You
Time to create page: 0.316 seconds
