7I37COM + MPG linking
6 years 6 months ago #164966 by viski
7I37COM + MPG linking was created by viski
I will connect MPG on 7i37COM . How to link encoder A and B to it ? Do i have to load encoder module , addf encoder ... just like it would be on parallel port ?
I will use 3 port . I/O from 49 to 72.
6 years 6 months ago #164972 by PCW
Replied by PCW on topic 7I37COM + MPG linking
Yes, you would have to add the software encoder, just like a parallel port
(except for the input signal names)
If you are running LinuxCNC 2.9 there is the possibility of using firmware with
the INM module that provides hardware debouncing and 4 MPG encoder channels
on GPIO pins
Time to create page: 0.279 seconds
