Lathe - tool offset in Y does not work
6 years 6 months ago #165591 by yaqwsx
In the top menu there is option to home Y axis. Also, home all homes everything.
How can AXIS change behavior of the G-code intereprer? I thought they are independent and G43 should behave the same... I have to check if my Mill configuration can do offsets in the Y direction.
6 years 6 months ago #165592 by cmorley
I do agree that seems weird.
I didn't search to see how far the LATHE=True switch manifests.
6 years 6 months ago #165593 by cmorley
what version of linuxcnc?
do you program a move in y after applying the offset?
6 years 6 months ago - 6 years 6 months ago #165641 by yaqwsx
Today I solved the problem. It was my own stupidity.
When G43 is called, the interpreter will apply the tool offset not in the next move but it applies the offset by components - when the individual axes move. Therefore, since my program does not contain any Y-axis movements, the correction was never applied. Instead, once G43 was called, the axis immediately changed its position to -offset.
To fix it, I modified my post-processor to produce tool change like this:
T1 M6 G43 G0 Y0
Last edit: 6 years 6 months ago by yaqwsx.
