Program takes roughly three times longer to run than it should
6 years 6 months ago #166221 by tommylight
Linuxcnc will show you how much time it takes at the rate that is in gcode, file>properites menu will shot time also, but again only for the feed rate.
6 years 6 months ago - 6 years 6 months ago #166317 by Todd Zuercher
I wasn't able to look at what your file looks like, but for some milling files the machine's acceleration times can make significant differences in what the actual milling time is, especially on machines with low accelerations and high feed rates. The machining time estimate in Linuxcnc does not make any allowance for machine accelerations, and none of the run time estimators in cam programs I've used do either, other than sometimes adding a time percentage to the estimate as a fudge factor. The result is files that have lots of changes in direction with short moves can have the actual milling times be wildly different from their estimated time. (I have never tried Fusion360.)
Be sure that the feeds specified in your files are within the capabilities of your machine and the feed rate limits you programed into your ini file.
Last edit: 6 years 6 months ago by Todd Zuercher.
6 years 6 months ago #166332 by bbsr_5a
also the effect of G61 vs G64 P0,1
did make on plasma a 30% decrease in Cutting time
Time to create page: 0.189 seconds
