I have linuxcnc working on both my mill and lathe. I also have a vistaCNC pendant which is a godsend. It allows me to both move any axis using the rotary controller and by holding down buttons to move any axis in either positive or negative directions and there are easy to use functions for setting the rate. This makes it better to use the LinuxCNC interface & pendant for manual operations than it would be to operate cranks.
What I want to do is move any axis manually by entering a numeric value on the keyboard. Is there a way in LinuxCNC where I could put a cursor into a value field, select the axis I want to move, and enter a specific distance and have that particular axis move that amount?
Although I am able to create gcode files and run them from beginning to end, I really feel the need for more direct control of basic routines. I have seem FernV's files, but have gotten overwhelmed trying to get them to function. Is there a better alternative for this sort of conversational control?
With all of LinuxCNC's capabilities, there ought to be a way to permit this sort of control. I have a stepper controlled rotary table for my mill and I would like to attempt cutting gears. Of course I could draw the item in CAD and generate a gcode milling file that would make the entire part. But, why couldn't I figure out how much rotation I need between teeth and just keep advancing the rotary manually by that fixed amount?
