parallel port no longer detected by LinuxCNC and neither by dmesg, failed?
05 May 2020 09:24 #166748 by gzcwnk
It was working but I tried a new BOB as the one I had was failing and well I am wondering if the new BOB damaged the PP card?
05 May 2020 10:05 #166749 by tommylight
What voltage does the BOB use ?
Is it a PCI add on or built in parallel?
05 May 2020 10:18 - 05 May 2020 10:20 #166750 by gzcwnk
The Bob has a seperate 24v dc supply. PCI add on card
dmesg (dmesg | grep para) doesnt show a paraport
Last edit: 05 May 2020 10:20 by gzcwnk.
05 May 2020 10:23 #166751 by gzcwnk
Actually sorry my error should be dmesg |grep parp NOT para
so its there just not working?
05 May 2020 10:23 #166752 by tommylight
Insert the card into another PCI slot if available, if not, clean the contacts on the card and motherboard.
And 24V will mess it up if any miss wiring occurred.
05 May 2020 10:28 #166753 by gzcwnk
How could I mis-wire it? its optically isolated?
05 May 2020 10:42 #166757 by tommylight
Some yes, some no.
05 May 2020 10:44 #166758 by gzcwnk
OK, is it possible the address has moved and linuxCNC cant see it any more?
05 May 2020 10:47 #166760 by tommylight
Yes it is, and to prevent that from happening you have to set the BIOS to manually assign addresses and IRQ.
05 May 2020 10:48 #166761 by tommylight
Did you just post another topic and then delete it ?
It was there, now it is not, something about a Dell 9020 ? :(
Time to create page: 0.145 seconds
