How to add ENTER button in macro XHC pendant
6 years 5 months ago #168078 by Marcodi
I would like to ask the simple question how you write a subroutine o<presenter> sub
I want to add that to one of the macro keys on my xhc pendant to not have to walk to the computer during a manual tool change.
I hope someone has a simple answer how to make it seem the enter button is pressed on the keyboard by means of an xhc pendant
6 years 5 months ago #168087 by fixer
The question is really how to confirm manual tool change remotely.
The answer depends on your configuration and user interface you are using.
The following hal example should get you started:
#based on axis_manualtoolchange.hal loadusr -W hal_manualtoolchange # in case they were linked already unlinkp iocontrol.0.tool-change unlinkp iocontrol.0.tool-changed net tool-change hal_manualtoolchange.change iocontrol.0.tool-change net tool-changed hal_manualtoolchange.changed iocontrol.0.tool-changed net tool-prep-number hal_manualtoolchange.number iocontrol.0.tool-prep-number #change XHC.BUTTON to the pin name of your preferred button on the pendant net change_button hal_manualtoolchange.change_button XHC.BUTTON
6 years 5 months ago #168095 by Marcodi
Hi fixer,
Thanks for this, but you are taking it a step to far. I am already using the manual tool change script with auto touchoff. That works perfectly. There is just a dialog box that pops up on toolchange and requires pressing enter to continue the script. I want to keep that dialog box I just want to be able to press enter aswell on my pendant instead of my keyboard .
So that is what I am looking for. A code to simulate like you really just press enter on the keyboard but that in one of the macro keys.
Any idea how I do that?
6 years 5 months ago #168110 by fixer
Have you even tried to run my hal? It will do exactly this. It will show dialog to ask for a tool, and it will hide the dialog when you press the button on the pendant. You can still hide the dialog with enter or click on ok as before.
If your config does not use hal_manualtoolchange you will need to post relevant hal and ini sections, so we can find a better solution.
If you insist of pressing the enter key, it is possible to write a userspace python component that simulates keypress with "uinput" module. But this is not the right way to do it
6 years 5 months ago #168201 by Marcodi
Ok, I will try your code. I thought it was way further than what I needed. But I will try it so i can give you the feedback if my system is set up as you think it is.
I will let you know soon.
Thx for the help already
6 years 5 months ago #168219 by MovT
I am interested in the test result too.
Time to create page: 0.308 seconds
