Setpoint Mcode
6 years 4 months ago - 6 years 4 months ago #170344 by Aciera
Replied by Aciera on topic Setpoint Mcode
One problem is to create a pulse when the laser sensor detects the work piece as it will not change back to 0 before the piece is past. I know only how to do that in classicladder.
That leads to the next challenge of signal speed because the work piece is moving and the signal of the laser sensor will require some time to be fed through the electronics and software. So by the time the DRO is set to "0" the work piece is going to be already past the sensor by some distance. There is no avoiding this but with a real time system you might be able to figure out how much offset the system has depending on the speed of the work piece.
Measuring the length of the piece might actually be the easier task because it involves also the negative edge and the delay in the second edge would compensate for the delay in the first.
Last edit: 6 years 4 months ago by Aciera.
6 years 4 months ago #170365 by lorisdag
Replied by lorisdag on topic Setpoint Mcode
Ciao ho risolto mettendo uno switch manuale per fare la seconda lettura e tutto funziona
6 years 4 months ago #170465 by lorisdag
Ciao si รจ molto simile la provero appena possibile grazie
Time to create page: 0.356 seconds
