Helllpppppp for 7i93
- newrock
09 Jul 2020 13:03 - 09 Jul 2020 13:06 #174088
by newrock
Helllpppppp for 7i93 was created by newrock
Last edit: 09 Jul 2020 13:06 by newrock.
- Thank you received: 6575
09 Jul 2020 13:59 #174093
Replied by tommylight on topic Helllpppppp for 7i93
Moved to driver boards category.
- Thank you received: 4860
09 Jul 2020 14:50 #174096
Replied by PCW on topic Helllpppppp for 7i93
There is no pncconf support for that board configuration
but you could use pncconf with a similar card to created a hal/ini file set
for the 7I93.. You would then have to create the card name and driver lines
in the hal file to match the 7I93
I would start with a pncconf configuration for the 7I49 (maybe 5I23+7I49)
The following user(s) said Thank You: newrock
- newrock
13 Jul 2020 11:43 #174495
by newrock
Replied by newrock on topic Helllpppppp for 7i93
thank you for answer,
I tried but there is no 7i49 in 5i23.
if you have example hal and ini files, can you send me? or where can I find!!!
Thanks.
Thanks.
13 Jul 2020 14:16 #174509
OK another option is to setup a 5i23 config for a normal encoder setup
(or 7I93 config if you have 2.9) and change the encoder hal pins to resolver
pins.
for 2.7 this would look something like this:
setp hm2_[HOSTMOT2](BOARD).0.resolver.00.scale [AXIS_0]INPUT_SCALE
net motor.00.pos-fb hm2_[HOSTMOT2](BOARD).0.resolver.00.position => pid.0.feedback
basically replace all encoder instances with resolver (then delete the encoder lines that are not appropriate for resolver like count mode)
pins.
Time to create page: 0.101 seconds
