Command M3 doen´t work properly
6 years 3 months ago #176702 by Marfil
Hi every one..
I have a problem since this morning on my cnc router. right now does NOT respond to the M3 command.
when I use the "push buttom" in graphical interface, everything is fine, but it doesn't respond to the line command send.
All other M5, M7, M8, M9, M1 commands works OK.
I notice that the M3 works in "reverse" (¿?) if I turn on the spindle engine through the graphical interface, when I send the M3 command, it "turns the spindle motor to off" (¿?) Just like M5 does. So I have two ways to cut off the motor, M3 and M5
Can someone give me a hand with this issue?
Thanks in advance... Marfil
6 years 3 months ago #176708 by tommylight
6 years 3 months ago #176731 by Marfil
Thanks a lot, next week I Try it.
6 years 2 months ago #177058 by Marfil
Finally your're right. It was the solution.
Thanks a Lot.
Marfil
