vfd reverse hitaachi w200
  • jefsaro
  • jefsaro's Avatar Topic Author
  • Premium Member
  • Premium Member
20 Oct 2020 12:08 #186675 by jefsaro
vfd reverse hitaachi w200 was created by jefsaro
hello friends, after several hours to find all the solutions to reconnect the hitachi vfd, it finally works, I have 2 problems, I only know how to run it in one direction, and the second, I don't know how to run it axis office.
can you help me??
20 Oct 2020 12:29 - 20 Oct 2020 12:32 #186677 by Aciera
Replied by Aciera on topic vfd reverse hitaachi w200
I'm not sure what you mean by this:
How you change the rotation direction would depend on how you wire the vfd:
Last edit: 20 Oct 2020 12:32 by Aciera.
  • jefsaro
  • Premium Member
  • Premium Member
20 Oct 2020 14:23 #186686 by jefsaro
Replied by jefsaro on topic vfd reverse hitaachi w200
i work whit 2 wires rv and fw
20 Oct 2020 14:24 #186688 by andypugh
Replied by andypugh on topic vfd reverse hitaachi w200
How are you driving the FWD and REV inputs? What interface card? What are your HAL connections?
  • jefsaro
  • Premium Member
  • Premium Member
20 Oct 2020 14:33 #186689 by jefsaro
sorry my english is very bad , i work whit mesa 6i25and 7i76 i post ini and hal files in first message
  • jefsaro
  • Premium Member
  • Premium Member
20 Oct 2020 14:33 #186690 by jefsaro
and 0 -10v
20 Oct 2020 14:43 - 20 Oct 2020 15:04 #186693 by Aciera
So far you have:
net spindle-output      => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable      => hm2_5i25.0.7i76.0.0.spinena
net spindle-ccw         => hm2_5i25.0.7i76.0.0.spindir
With your setup you could wire the "hm2_5i25.0.7i76.0.0.spinena"-contact to FW-input on the vfd and
the "hm2_5i25.0.7i76.0.0.spindir"-contact to RV-input on the vfd.
Then you could do a bit of logic in the hal file:
net spindle-enable => and.vfd-fw.in0 =>and.vfd-rv.in0
net spindle-cw => and.vfd-fw.in1
net spindle-ccw => and.vfd-rv.in1
net vfd-fw <= and.vfd-fw.out => hm2_5i25.0.7i76.0.0.spinena
net vfd-rv <= and.vfd-rv.out => hm2_5i25.0.7i76.0.0.spindir
Last edit: 20 Oct 2020 15:04 by Aciera. Reason: hal code suggestion does not work as spinena is connected to spinout in the 7i76
20 Oct 2020 14:50 #186695 by andypugh
So you did, sorry.
net spindle-enable             <=  motion.spindle-on
net spindle-cw                 <=  motion.spindle-forward
net spindle-ccw                <=  motion.spindle-reverse
net spindle-brake              <=  motion.spindle-brake
I think that the issue is that the outputs of the mesa spindle interface are spindle-on and spindle-reverse. So when the spindle is running backwards both the FWD and REV inputs to the VFD are active, and it interprets that as a FWD.
You might need to move the VFD FWD terminal off of the 7i76 spindle connector and use a GPIO pin instead. (I don't think that the spindle connector on the Mesa card is configurable)
An alternative is to use a small relay to disconnect the "FWD" signal when the "REV" signal is high.
20 Oct 2020 14:58 - 20 Oct 2020 15:03 #186699 by Aciera
Ah, I think Andy could be right. The spinena might be connected to the spinout on the 7i76. So you would use the spindir output to channel the spinena signal to either FW or RV-input of your vfd.
I just checked in the manual:
The SPINENA output is special as it uses the same signal that enables the analog output. When the analog output is enabled, theSPINENA OPTO output is on.
So Andy has it right.
Last edit: 20 Oct 2020 15:03 by Aciera.
  • jefsaro
  • Premium Member
  • Premium Member
20 Oct 2020 15:10 #186700 by jefsaro
i test , but error
Time to create page: 0.214 seconds
