How to disable manual movement to axis
5 years 10 months ago #191690 by aleksamc
I want to make automation for CNC machine using 7i77 mesa board for analog servos.
CNC will move big saw. Saw will rotate 90 degree to X and to Y axis.
So I need to make such logic:
- when saw in X direction AND turned on - forbid to move in Y directio.
- same forbid for X direction if saw will be in Y direction.
How to do this? What pins should I operate to forbid movement?
5 years 10 months ago #191771 by cmorley
You are talking about when in manual mode?
You can of course use HAL code to limit external jogging, but to limit GUI jogging would require custom GUI code.
Chris
5 years 10 months ago - 5 years 10 months ago #191858 by aleksamc
Yes, I talk about manual mode.
So you mean I need to make custom GUI?
Ok, I will try that. Thanks
Last edit: 5 years 10 months ago by aleksamc.
5 years 10 months ago - 5 years 10 months ago #191907 by Himarc3D
Or you can use relay logic circuit (not classic ladder) many machinery still working just using relays.
Better you learn to code yourself but untill you get it you can run using relays.
Elegant, fancy codes you will try to see and learn usually are hard to troubleshoot and maybe the machine downtime will be high, youll spend more time coding/troubleshooting instead making money
Last edit: 5 years 10 months ago by Himarc3D.
5 years 10 months ago #191909 by cmorley
Using relays to disconnect the motors from commands is like using a hammer.
If the motor is a servo then that is not going to work at all - you lose PID control.
It's also not friendly to the user - and easy to screwup linuxcnc's idea of where it's at.
Yes a customized screen would be the best course.
Some screens are easier to customize then others.
5 years 10 months ago #191915 by Himarc3D
I see, agree with your points.
I guessed he use 3 phase motor for the saw and the servos is to control the axes. Nice to kwon new machines come with servo to run the saw.
Here at the shop we have 3 old bandsaw machines and for the saw is running 3phase, the oldest one dont have VFD and use 200V logic with just bunch of relays this machine maybe have 35 years old now and no downtime, circuit is simple but just cut the other have automatic length feeder, counter, memory etc
Time to create page: 0.259 seconds
