- Thank you received: 67
How to disable manual movement to axis
- aleksamc
- Topic Author
CNC will move big saw. Saw will rotate 90 degree to X and to Y axis.
So I need to make such logic:
- when saw in X direction AND turned on - forbid to move in Y directio.
- same forbid for X direction if saw will be in Y direction.
How to do this? What pins should I operate to forbid movement?
- Thank you received: 2181
You can of course use HAL code to limit external jogging, but to limit GUI jogging would require custom GUI code.
Chris
- aleksamc
- Topic Author
So you mean I need to make custom GUI?
Ok, I will try that. Thanks
- Himarc3D
- Thank you received: 49
Better you learn to code yourself but untill you get it you can run using relays.
Elegant, fancy codes you will try to see and learn usually are hard to troubleshoot and maybe the machine downtime will be high, youll spend more time coding/troubleshooting instead making money
If the motor is a servo then that is not going to work at all - you lose PID control.
It's also not friendly to the user - and easy to screwup linuxcnc's idea of where it's at.
Yes a customized screen would be the best course.
Some screens are easier to customize then others.
- Himarc3D
I guessed he use 3 phase motor for the saw and the servos is to control the axes. Nice to kwon new machines come with servo to run the saw.
Here at the shop we have 3 old bandsaw machines and for the saw is running 3phase, the oldest one dont have VFD and use 200V logic with just bunch of relays this machine maybe have 35 years old now and no downtime, circuit is simple but just cut the other have automatic length feeder, counter, memory etc
- Himarc3D
- aleksamc
- Topic Author
Or you can use relay logic circuit (not classic ladder) many machinery still working just using relays.
Previously I made such think. I remade automation of old CNC machine to Logo Siemens small PLC and Relays. Analog input to servos I made with analog potentiometers and stepping with voltage deviders.
It was funny and fast. But here I want to make such thing with remaking cnc to linuxcnc control.
Servos has one small disadvantage:
If you give them 0V to control input, they will still move, nevertheless how you configured "BIAS", it will move 1mm per minute but move.
When you use CNC control with PID regulator, bias will be always compensated.
- Himarc3D
I was thinking you are talking different thing, just want stop the blade induction motor, good Cmorley come to enlighten us and i dont messes your stuff.
What are you doing?
You dont use induction motor to control speed, you need precision to stop your saw?
So many machine types
- aleksamc
- Topic Author
In this one I want to change concept.
I was made like this in example
