5 DoF robotic arm speed control
12 Dec 2020 10:18 #191722 by elisa
5 DoF robotic arm speed control was created by elisa
Hi everybody,
I have a 5 DoF robotic arm controlled via LinuxCNC. I have a problem with speed, when the robot gets to cornerns it starts shaking and it stops moving for a while, but when it is far from corners it follows the path perfectly and smoothly .
I read in the documentation that It would be useful the command G64 Pxx, but I tried it and it wasn't good at all.
Can anyone have any other suggestions?
Please, write me soon.
12 Dec 2020 16:53 #191738 by Aciera
Replied by Aciera on topic 5 DoF robotic arm speed control
Do you use a special kinematic or are you commanding the joints directly?
12 Dec 2020 16:55 - 12 Dec 2020 16:57 #191739 by elisa
Replied by elisa on topic 5 DoF robotic arm speed control
I am using trivial kinematics
Last edit: 12 Dec 2020 16:57 by elisa.
13 Dec 2020 10:50 #191844 by elisa
I am using trivial kinematics, any suggestions?
13 Dec 2020 13:56 #191860 by Aciera
Have a look at genserkins:
linuxcnc.org/docs/2.8/html/motion/dh-parameters.html
I'm working on a 6 axis Mitsubishi robot:
forum.linuxcnc.org/10-advanced-configura...th-simulation#158467
Also, when using non-trivial kinematics it's very handy to be able to switch between the non-trivial and the trivial kinematic:
www.panix.com/~dgarrett/stuff/switchkins.html
The following user(s) said Thank You: elisa
14 Dec 2020 09:24 #191948 by elisa
It would be interesting to use generkins, but I have read that it doesn't check the end effector postion in relation to the joint limits.
However, do you think that the speed problem is due to trivial kinematics?
I also add encoders on each joint and set microstepping to have smooth movements. Anyway, when it reaches the corners it starts to shake or pause for a while, and then goes on smoothly.
14 Dec 2020 11:14 - 14 Dec 2020 11:15 #191953 by andypugh
Replied by andypugh on topic 5 DoF robotic arm speed control
No, trivial kins should just work.
What type of motors and drivers move the joints?
This sounds like it could be a PID tuning problem.
Last edit: 14 Dec 2020 11:15 by andypugh.
14 Dec 2020 11:34 #191954 by elisa
Optical incremental encoders and stepper motors
14 Dec 2020 11:37 #191955 by andypugh
What stepper drivers? What it the interface between LinuxCNC and the drivers?
Can you attach the HAL file?
14 Dec 2020 12:27 #191958 by elisa
This is an extract. Some parameters are defined in the coorespondent file .ini such as [AXIS_0]STEPLEN
I use DRV8825 driver, and the interface is via Mesa cards.
File Name: extract.txt
File Size:1 KB
Time to create page: 1.485 seconds
