constant velocity
5 years 10 months ago - 5 years 10 months ago #192146 by tommylight
Replied by tommylight on topic constant velocity
You can AND the e-stop or machine is enabled with the DOUT, so when disabled or e-stopped it will also turn off the output.
It requires adding 3 or 4 lines in hal.
www.google.com/search?source=hp&ei=eETaX...I1C_4Q4dUDCAY&uact=5
Last edit: 5 years 10 months ago by tommylight. Reason: wrong link.
The following user(s) said Thank You: ahmetbm
5 years 10 months ago #192230 by ahmetbm
Replied by ahmetbm on topic constant velocity
ahmetbm wrote: I tried to use M64-M65 for signal activation because i need a signal to trigger a relay, but unfortunately M64-M65 is active after e-stop is triggered.
If any advice to use different way that i could not find in linuxcnc, i apreciate it.
I am sorry my explanation is wrong, in fact M64-65 is stopped by e-stop, however it is activated as soon as i removed e-stop , before i make any jogging or another preparation. So the signal must stay de-active until i press start.
5 years 10 months ago #192328 by ahmetbm
tommylight wrote: You can AND the e-stop or machine is enabled with the DOUT, so when disabled or e-stopped it will also turn off the output.
Thanks for the tip, i was able to manage the needs, however i was avoiding manual jogging, but i used to solve the problem
Time to create page: 0.136 seconds
