estimate program runtime searched
30 Dec 2020 08:53 - 30 Dec 2020 08:56 #193549 by chris@cnc
expected program runtime searched was created by chris@cnc
Hello,
The expected program runtime can be seen in file -> properties. Is there a way to export this signal to Pyvcp? I want to run my program runtime timer backwards and need the expected runtime for the calculation.
Last edit: 30 Dec 2020 08:56 by chris@cnc.
30 Dec 2020 16:00 #193586 by skunkworks
Replied by skunkworks on topic expected program runtime searched
First - to you quiestion - I don't know. Second - the estimate is very very poor.
sam
  • Moderator
  • Moderator
30 Dec 2020 16:24 - 30 Dec 2020 16:25 #193587 by tommylight
Replied by tommylight on topic expected program runtime searched
The estimate is very precise, it just does not include anything except the feed distance at the given feed rate. So rapids, tool changes, acceleration/deceleration, probing, etc are not included.
Last edit: 30 Dec 2020 16:25 by tommylight. Reason: typo
30 Dec 2020 17:02 #193589 by skunkworks
Exactly.. :)
30 Dec 2020 17:13 #193590 by chris@cnc
Replied by chris@cnc on topic expected program runtime searched
And that's the point. I don't have a tool changer. And so it's good to know when to be back. 5 minutes don't matter. But I have 4 cores and I no longer want to do their work. They are better at calculating and with a little offset the estimate fits usefully.
  • Moderator
  • Moderator
30 Dec 2020 17:53 #193595 by tommylight
For Plasma, since there are probing and waiting for the arcok signal besides the rapids and accel/decel, i just double the value that i get from file>properties.
It usually is near enough, but when it has to do a lot of pierces/probes/waits i tend to triple the time. That requires a bit of experience with the machine and types of work.
30 May 2021 09:09 - 30 May 2021 09:10 #210678 by chris@cnc
Replied by chris@cnc on topic estimate program runtime searched
I found the calculation of the estimated program runtime in /usr/bin/axis from line 1964 to 2018. Could someone point me to the variable where this time is written?
I would export to the pyvcp panel and calculate backwards to zero
def gcode_properties(event=None):
        props = {}
        if not loaded_file:
            props['name'] = _("No file loaded")
        else:
            ext = os.path.splitext(loaded_file)[1]
            program_filter = None
            if ext:
                program_filter = inifile.find("FILTER", ext[1:])
            name = os.path.basename(loaded_file)
            if program_filter:
                props['name'] = _("generated from %s") % name
            else:
                props['name'] = name
            size = os.stat(loaded_file).st_size
            lines = int(widgets.text.index("end").split(".")[0])-2
            props['size'] = _("%(size)s bytes\n%(lines)s gcode lines") % {'size': size, 'lines': lines}
            if vars.metric.get():
                conv = 1
                units = _("mm")
                fmt = "%.3f"
            else:
                conv = 1/25.4
                units = _("in")
                fmt = "%.4f"
            mf = vars.max_speed.get()
            #print o.canon.traverse[0]
            g0 = sum(dist(l[1][:3], l[2][:3]) for l in o.canon.traverse)
            g1 = (sum(dist(l[1][:3], l[2][:3]) for l in o.canon.feed) +
                sum(dist(l[1][:3], l[2][:3]) for l in o.canon.arcfeed))
            gt = (sum(dist(l[1][:3], l[2][:3])/min(mf, l[3]) for l in o.canon.feed) +
                sum(dist(l[1][:3], l[2][:3])/min(mf, l[3])  for l in o.canon.arcfeed) +
                sum(dist(l[1][:3], l[2][:3])/mf  for l in o.canon.traverse) +
                o.canon.dwell_time
            props['g0'] = "%f %s".replace("%f", fmt) % (from_internal_linear_unit(g0, conv), units)
            props['g1'] = "%f %s".replace("%f", fmt) % (from_internal_linear_unit(g1, conv), units)
            if gt > 120:
                props['run'] = _("%.1f minutes") % (gt/60)
            else:
                props['run'] = _("%d seconds") % (int(gt))
            min_extents = from_internal_units(o.canon.min_extents, conv)
            max_extents = from_internal_units(o.canon.max_extents, conv)
            for (i, c) in enumerate("xyz"):
                a = min_extents[i]
                b = max_extents[i]
                if a != b:
                    props[c] = _("%(a)f to %(b)f = %(diff)f %(units)s").replace("%f", fmt) % {'a': a, 'b': b, 'diff': b-a, 'units': units}
        properties(root_window, _("G-Code Properties"), property_names, props)
Last edit: 30 May 2021 09:10 by chris@cnc.
Time to create page: 0.191 seconds
