updated to 2.8 now tool change pauses
5 years 8 months ago #200159 by andypugh
Do you see the same in the sim configs?
5 years 6 months ago #207472 by rogerxue
no, SIM works fine. The issue is still here.
now I remap m6 (hope can bypass this issue), and have issue with "exception during generator call: TypeError: 'NoneType' object is not callable"
I find this is a similar issue with github.com/LinuxCNC/linuxcnc/issues/217 if I remove the epilog=change_epilog it will not have issue.
5 years 6 months ago #207541 by bevins
rogerxue wrote: no, SIM works fine. The issue is still here.
If you remove the change_epilog your machine wont be in a stable state if you do this in a remap. The change_epilog is responsible for setting toolchange flag to true and updating the parameters and dealing with the queuebuster.
You must be using an old stdglue that had this issue and it was resolved as far as I remember.
You should be able to fix it by replacing all return INTERP_* lines with yield INTERP_*.
5 years 6 months ago #207552 by rogerxue
Thanks, I did put it back, and the stdglue.py already have yield. And I think the stdglue.py is the latest with 2.8.1 build
5 years 5 months ago #207705 by rogerxue
I tried copy the file from master, or 2.8 to my local file, same error.
5 years 5 months ago #207918 by rogerxue
to the OP, it's a silly issue that the M1 stop was turned on, and after each tool change, my post have a m1 in there....
sorry
this is resolved now
Time to create page: 0.184 seconds
