Yaskawa servo options
5 years 8 months ago #198453 by dm17ry
Replied by dm17ry on topic Yaskawa servo options
eerr... what do you mean? didn't get it. what's "our driver"?
and i don't break anything with my patch - without that ini option everything behaves the usual way.
the thing is i currently support 8 servo control protocols and i'm not really thrilled having 16 sample ini files :) and more are on the way...
i've been using absolute encoders with MR-J2S-B's on my home mill for 10 year now... when i turn on the machine linuxcnc always comes up already homed. so i don't have a habit to rehome it. though it won't bring a slightest problem if i do it by accident or intentionally...
5 years 8 months ago #198526 by andypugh
Replied by andypugh on topic Yaskawa servo options
dm17ry wrote: eerr... what do you mean? didn't get it. what's "our driver"?
Typo. Should have been "your driver".
5 years 8 months ago #198527 by andypugh
dm17ry wrote: i've been using absolute encoders with MR-J2S-B's on my home mill for 10 year now... when i turn on the machine linuxcnc always comes up already homed. so i don't have a habit to rehome it. though it won't bring a slightest problem if i do it by accident or intentionally...
My absolute encoders aren't really absolute. What I have are single-turn-absolute resolvers and a bit of HAL that uses the position.txt file to work out where the axis really is.
Sometimes that file does not get saved, and I need to reset the system.
5 years 8 months ago #198539 by dm17ry
andypugh wrote: Typo. Should have been "your driver".
oh, ok. well, probably. i can keep motor motor offset in the amp eeprom or card's flash and output position which is 0 at home position. but already present motor-offset fit perfectly, so i thought it's a shame not to reuse it.. but i really like that now i have joints get homed automatically when amps say they are absolute. and unhomed when amps report position loss due to motor disconnection or discharged backup battery. seems like a natural behavior to me. what's the point of an open source software then if i have to give it up? ;)
btw, in the latest J5 series mitsubishi finally came up with battery-less absolute encoders. i haven't seen any in person yet, but as far as i understand they are harvesting motor's EMF to power up encoder electronics when an unpowered motor gets rotated by an outside force. pretty neat. because usually when backup batteries discharge after a few years and users miss it - just the right time to completely forget how to re-home the machine :)
5 years 8 months ago #198555 by andypugh
dm17ry wrote: [oh, ok. well, probably. i can keep motor motor offset in the amp eeprom or card's flash and output position which is 0 at home position. but already present motor-offset fit perfectly, so i thought it's a shame not to reuse it.
Can you give a link to documentation or code?
5 years 8 months ago #198949 by dm17ry
linuxcnc component description: yurtaev.com/nyx24.html
2.8 fork with my patches: github.com/yur7aev/linuxcnc/tree/nyx2.8
sample linuxcnc configs: github.com/yur7aev/linuxcnc/tree/nyx2.8/configs/nyx
Time to create page: 0.168 seconds
