Real Newbie needs some help and advice
5 years 8 months ago #197822 by Clive S
The Feral Engineer wrote: Check out my Linuxcnc videos. If you need me, email TheFeralEngineer@gmail.com. I'll give you a hand
youtube.com/channel/UC5Agp5Z6F1JiWihdO-QKkbQ
I have looked at your vids and I personally think you are doing a great job. The vid's are clear and concise with good camera work.
The following user(s) said Thank You: The Feral Engineer
5 years 8 months ago #197825 by robertspark
newbynobi wrote: @Knothead,
Wher are you located? This info might help to find personal assistence.
Help per TeamViewer etc. Can be a solution also.
As GUI I do recommend gmoccapy (may be I am a little bit influenced ;.) , as I do code that gui)
Norbert
OFF TOPIC
I do really like the visual appeal of Gmoccapy (but got totally lost trying to change it or move / remove something)... hence thought, start with AXIS until I get my head into Linux, linuxcnc, python, bash, .... qt5...
the GUI I like the most is QtPlasmaC.... but that is specialist / specific. I just like the simple colours (anything in black looks good / clear with a few other contrasting colours). personal opinion... would love to be competent enough to change QtPlasmaC (or create something similar) for 3 axis / 4 axis mill / router and 2 or 3 axis turn or lathe. (one day! I can but hope)
I do look in awe at what a few guys have created with patience, perseverance and time.
5 years 8 months ago - 5 years 8 months ago #197831 by robertspark
Back On Topic>>
If you want to convert from UC100 >> MESA hardware, the "quickest" way would be to buy a MESA 7i92M
store.mesanet.com/index.php?route=produc...69_62&product_id=302
depending upon where you are in the world, it is available from different / more local resellers.
you can then (after setting it up) plug in your DB25 cable and it will work as your present setup.
You then have a spare 26 PIN IDC connector for a second board if you wish or expand to other hardware the options are vast when you start to understand the MESA lineup + firmware options available should you wish to do something else.
Last edit: 5 years 8 months ago by robertspark.
5 years 8 months ago #197839 by Knothead
I am in Amherst, OH USA.
5 years 8 months ago #197974 by The Feral Engineer
There aren't enough thank yous for your feedback. I'm really glad people are enjoying the content. :)
The following user(s) said Thank You: Clive S, robertspark
5 years 8 months ago #198002 by robertspark
I second that, you youtube videos are great (presently working my way through them).
Can I suggest maybe breaking up your playlists a bit
maybe classicladder, HAL, etc. as some are part of a series and it will make it easier just to pick up on the sequence (IMO).
I was working my way through HAL and then you referenced something you did in classicladder, so I stopped and decided to start with classic ladder and then work my way forward.
maybe if you gave the playlists a prifix number, then you know which way to follow / work your way through the sequence and not having to step back.
Thanks for taking the time through at putting them together.
Time to create page: 0.157 seconds
