Shift Key jogging speed
5 years 8 months ago #200357 by tacklem60
Replied by tacklem60 on topic Shift Key jogging speed
Not to hijack the OP thread here, but i have been wondering the exact same thing in QTdragon. Shift+Jog doubles the slider jog rate which is certainly useful, however, im used to this functionality in Gmoccapy where shift+jog always gave me full rapid speed.
If there was a way to either set shift to always give full rapid or change it to a much higher number like 10x so it usually results in full rapid that would be great
5 years 8 months ago #200359 by cmorley
Replied by cmorley on topic Shift Key jogging speed
In qtDragon you would need to change the handler file (copy it in your config folder first)
then in this function :
def kb_jog(self, state, joint, direction, fast = False, linear = True): if not STATUS.is_man_mode() or not STATUS.machine_is_on(): self.add_status('Machine must be ON and in Manual mode to jog') return if linear: distance = STATUS.get_jog_increment() rate = STATUS.get_jograte()/60 else: distance = STATUS.get_jog_increment_angular() rate = STATUS.get_jograte_angular()/60 if state: if fast: rate = rate * 2 ACTION.JOG(joint, direction, rate, distance) else: ACTION.JOG(joint, 0, 0, 0)
change the rate = rate * 2 to
rate = INFO.MAX_TRAJ_VELOCITY/60
for max velocity - should do it.
The following user(s) said Thank You: tacklem60
5 years 8 months ago #200363 by tacklem60
Another perfect reply. I also was able to set my "slow" jog push button to 1/20 of the slider speed. I can now jog around at 250ipm (my rapid speed) by holding shift, release shift and move around at 60ipm to get close with my Haimer to set my WCS then hit slow and drop down to 3ipm to easily jog the rest of the way and sit my zero positions.
Basically the only 3 speeds I ever use on the machine all done without ever having to actually adjust jog speed. Such a simple quality of life improvement for the smallest of changes.
5 years 8 months ago #200373 by cmorley
excellent. I'm happy the customization ability of qtvcp has become utilized successfully by people like yourself. Thank you for the feeedback.
Chris
Time to create page: 0.051 seconds
